02-11-2008 02:44 AM - edited 03-05-2019 09:04 PM
Hello to all, 877 have just brought a shindy but I have problems to form the fastethernet, on having tried to form an ip address it(he,she) appears:
IP addresses may not be configured on L2 links.
Since I can solve it? I have tried to use the SDM but it(he,she) does not assign me ip for DHCP. Thank you very much
02-11-2008 03:04 AM
Only the Ethernet WAN interface can have an IP directly assigned. The LAN interfaces need to be assigned to a VLAN, which has the IP address.
Have a look at the following and post again if you still have trouble.
and this link has a complete sample config:
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/sampconf.html
Andrew.
02-11-2008 03:11 AM
Hello Andrew, I continue with the same mistake, not because it(he,she) does not warn me: (
02-12-2008 04:16 AM
use the interface vlan 1 command:
interface vlan 1
ip address x.x.x.x y.y.y.y
no shut
that shut do it!
