06-07-2006 10:59 AM - edited 03-05-2019 11:56 AM
Hello all, not sure if this is where I should post this but here goes. I have an 1811W and would like to set each Fast Ethernet port to have its own NAT defined.
Here's my reasoning. I am trying to setup a roll-over for my Internet connection. If the main line (cable) goes down, it will pick up the second line (DSL) automatically. I have the routing tables setup to do this, but the NAT does not work. It will only use the one that was designated for the main Fast Ethernet.
I do not want to go with something like OER (optimized edge routing), because that just seems more confusing and I do not know where to begin with that. Any help would be appreciated. thanks
Luke
06-07-2006 04:43 PM
hello Luke,
just to understand your scenario.
You said that you have "ip nat outside" in 2 interfaces and this is not working?
could you give us more details about your actual configuration.
vlad
06-07-2006 05:37 PM
Sure thing vlad. I will get the actual config when I go back to the office tomorrow.
