11-03-2011 11:17 AM - edited 03-07-2019 03:12 AM
Hello Everyone!
Let me start by saying that i am quite new to cisco equipment.
I have a new Cisco SF 300-24 and try to configure a static VLAN.
I changed die Administrative PVID for a few ports from 1 (Default-VLAN) to 10 (my new VLAN is Static) in Interface Settings.
Now I can't ping from my PC to the Switch on the ports I have changed.
Any help would be appreciated,
Thanks!
Jürgen
11-03-2011 12:22 PM
if you change the vlan for a port and you want to communicate with the switch IP address then you have to configure a new interface VLAN with the id of new VLAN.
Alain.
11-16-2011 06:32 PM
Hi Jürgen,
You have to have inter-vlan routing here to ping a PC which in different VLAN than yours.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
Krishna
12-05-2011 04:57 PM
Based on your description I can only assume that the management IP for your switch is configured on the default vlan 1.
If you want to be able to access the switch from both vlan 1 and vlan 10 you will need to configure a router with access to both vlans. Alternately if you want to access the switch on vlan 10 only you will need to change the management vlan on the switch.
