Speed - auto - in a Fastethernet interface in a Router
fjcardenas-1
Is there auto-negotiation when you connect a router FaX/X to a switch interface? I know how to check if speed and duplex are auto in a Switch... how can you see this in a router (command)?
hi, from your question, i believe to use the follwing command to know either auto-nego or not:
"show run int fax/x" to see the configuration of a particular interface. If you do not see Speed 100 and duple-full, then your port is auto-nego.
8 Replies 8
Jon Marshall
Yes there is auto-negotiation providing the switch port is set up for auto-negotiation. If you wanted to set the interface to a specific speed/duplex on a router interface
int fa0/0
speed 100
duplex full
Jon
My specific question is how can I see (which command) that an interface chose the speed and duplex setting with auto-negotiation? With a switch you use the sh int status command... what command do you use in a router?
Thanks.
Sorry i wasn't specific enough. If there are not speed/duplex entries under the interface configuration then it is using auto-negotiation. That is how you can tell.
Jon
Try using "show interface "
You should get an output similar to the following. I have marked the point where the duplex is displayed.
FastEthernet0 is up, line protocol is up
Hardware is xxx, address is 0018.19c2.fc8c (bia 0018.19c2.fc8c)
Internet address is A.B.C.D/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 153000 bits/sec, 69 packets/sec
5 minute output rate 137000 bits/sec, 77 packets/sec
26788744 packets input, 2250783189 bytes
Received 1 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
27330053 packets output, 2049402608 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 lost carrier, 0 no carrier
Andrew
ciscosupport99
...show interfaces status -
The output of "show interfaces" shows the speed and duplex settings but it doesn't show if it got those settings by auto-negotiation or manually... how to know if it got them with auto-negotiation?.
If there is nothing connected to it you can tell by, if it would say auto where it shows duplex and speed. See below is a show interface of a port set to auto.
