Community Member
speed configuration of SFP port on catalyst 3750
Can I configure the speed (10/100/1000) in a SFP port ?
1 ACCEPTED SOLUTION
Re: speed configuration of SFP port on catalyst 3750
Hi Smart,
May be this link will answer what you are looking for
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_tech_note09186a00807a30d6.shtml#config1
Ankur
Hi Smart,
Ankur
bjw Silver
Silver
What type of SFP is it?
Community Member
I discovered (in a bad way) that I cannot configure the speed. I needed to temporary configure it for 100 Mbps, but I couldn?t. So I went to another solution.
Thank you very much for the responses.
Best Regards.
391
