Community Member
Trouble setting ACL between two VLAN's
Hi all. I am having trouble restricting communication between 2 VLAN's via ACL's. What I am trying to do is configure an ACL that allows VLAN-3 (10.10.30.0) to only be able to talk to 3 specific hosts on VLAN-2 (i.e. 10.10.20.15 - 10.10.20.17).
If I apply acl-30 to vlan-3's outbound, then I have full communication between the 2 networks - so I know the physical setup of the network is ok. However, if I apply acl-130 to vlan-3's outbound in replace of acl-30 then then ALL communication is blocked between the 2 VLAN's including the 3 specific hosts. I can however ping the gateways.
The following is the pertinent portion of my running config:
interface Vlan2
ip address 10.10.20.1 255.255.255.0
ip access-group 20 out
ip access-group 21 in
ip nat inside
ip virtual-reassembly
interface Vlan3
ip address 10.10.30.1 255.255.255.0
ip access-group 130 out
ip access-group 31 in
ip nat inside
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet0 overload
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 1 permit 10.10.20.0 0.0.0.255
access-list 1 permit 10.10.30.0 0.0.0.255
access-list 20 permit 10.10.20.0 0.0.0.255
access-list 20 permit 10.10.30.0 0.0.0.255
access-list 21 permit 10.10.20.0 0.0.0.255
access-list 21 permit 10.10.30.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 30 permit 10.10.30.0 0.0.0.255
access-list 30 permit 10.10.20.0 0.0.0.255
access-list 31 permit 10.10.20.0 0.0.0.255
access-list 31 permit 10.10.30.0 0.0.0.255
access-list 130 permit ip 10.10.30.0 0.0.0.255 host 10.10.20.15
access-list 130 permit ip 10.10.30.0 0.0.0.255 host 10.10.20.16
access-list 130 permit ip 10.10.30.0 0.0.0.255 host 10.10.20.17
Please advise.
2 ACCEPTED SOLUTIONS
Hall of Fame Super Blue
Re: Trouble setting ACL between two VLAN's
You are applying acl 130 in the wrong direction.
inbound on an vlan interface is for traffic coming from hosts on that vlan
outbound on a vlan interface is for traffic going to hosts on that vlan
so you need to apply acl 130 inbound.
Jon
Can you post your updated config.
As for inbound/outbound think of it from the perspective of the vlan interface.
If a packet arrives inbound on the vlan interface then it has come from a client machine on that vlan. So when a client on that vlan transmits a packet destined for a machine on another vlan the client must send the packet to it's vlan interface ie. the packet arrives inbound on the vlan interface.
Outbound means any packet going to a client on that vlan. Again think of from the perspective of the vlan interface. If it needs to send a packet to client on it's own vlan it will send a packet out of it's interface.
Does this help ?
Jon
Jon
Community Member
Inbound on VLAN-3 ?
"Inbound on VLAN-3 ?"
Yes.
Community Member
Ok, it is working, somewhat...
Sending a ping to .15 .16 or .17 works as expected. Sending a ping to a host that should not be allowed to communicate responds as follows:
#1 Ping from 10.10.30.4 to 10.10.20.9:
Reply from 10.10.20.9: bytes=32 time=3ms TTL=127
Reply from 10.10.30.1: Destination net unreachable
#2 Ping from 10.10.30.4 to 10.10.20.9:
#3 Ping from 10.10.30.4 to 10.10.20.9:
Request timed out.
Why the 3 different responses on 3 different pings. Shouldn't the communication be blocked at all times? Or did I ping too fast after issuing the command to the router?
Also can you explain the following a bit more:
"inbound on an vlan interface is for traffic coming from hosts on that vlan
outbound on a vlan interface is for traffic going to hosts on that vlan"
This was completely opposite from what I was thinking, and is a bit confusing.
Does this help ?
Jon
Community Member
Hey Jon,
How come he's got an inbound and outbound ACL per VLAN interface?
Purple
To accomplish what he wants all he needs is ACL 130 on the inbound direction .
nterface Vlan3
ip access-group 130 in
ip nat inside
Community Member
Thanks for the help Jon, and the explanation. I think I was just pinging the router too quickly (within 30 seconds) after I uploaded the config file. Everything seems to be working now.
322
