Two outside IP's to two inside IP's
jokubaszilenas
I am new in Cisco configuration. I have Cisco 871 router. Now I have one outside IP and one inside IP. The ISP gave one more outside IP. I want to do that second outside IP mapped to unused ethernet port.
7 Replies 7
Roman Rodichev
Level 7
Level 7
Are both outside IPs routed to the outside interface? Are you trying to map the 2nd IP to another inside IP? Just configure "ip nat inside source static <2nd_outside_IP>". Sorry if this doesn't answer your question.
Roman
Ganesh Hariharan
you mean both the outside ip are in different subnet or in the same subnet.If different subnet just enter into serial or ethernet interface and type ip address "ip address" mask.
Ganesh.H
i have no luck with NAT.
Both outside IP's are in one subnet. Can you tell all steps how to do it?
An example might help.
inside interface of router =  fa0/0  192.168.5.1
outside interface of router = fa0/1
new public ip address = 195.17.17.10
lets say you want to present an internal 192.168.5.10 address as the new public IP address -
config would be as follows
int fa0/0
ip nat inside
ip fa0/1
ip nat outside
ip nat inside source static 192.168.5.10 195.17.17.10
Jon
I changed my configuration with this and no luck:
interface Vlan2
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface FastEthernet2
switchport access vlan 2
ip nat inside source static 192.168.2.1 *.*.134.20
my router configuration is:
Building configuration...
interface FastEthernet0
interface FastEthernet1
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ETH-WAN$$ES_WAN$
ip address *.*.134.14 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
interface Vlan2
ip nat inside
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 100 interface FastEthernet4 overload
ip nat inside source static 192.168.2.1 213.197.134.20
end
can ping somthing in the internet
using ping x.x.x.x source vlan 2
then do show ip nat translation and see if the translation happning or not
if not post the debug ip nat detail   here
ok hope this link will help you to configure Natting in your environment !!
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
Ganesh.H
