08-12-2007 06:54 PM - edited 03-05-2019 05:51 PM
I have a iBook G4. Console cable, and USB to Serial adapter cable. I would like to be able to console into a Cisco router, I am using Zterm as was recommanded early for Hyperterminal. it seems that the connection is there. when I click on the Zterm app I get a blank white screen with
ATE1 V1
OK
any one have any idea how to use this terminal or help get connected
I know that I can use Terminal to telnet into the router, but I need to console in first to set up the basic configuration.
Solved! Go to Solution.
08-14-2007 11:19 PM
Hi Karim,
Please try this driver:
HTH,
Mohammed Mahmoud.
08-20-2007 05:49 AM
Hi Karim,
I am very glade that you did it :) please do enjoy your lab, i'll always be here if you have further problems, and thanks for the nice rating.
HTH,
Mohammed Mahmoud.
08-12-2007 08:57 PM
HI,
You can use "Hyperterminal" for this kind of Setup.
Setup as below:
Bits per sec : 9600
Data bits : 8
Parity : none
Stop bits : 1
Flow control : none
PLS RATE if HELPS
Best Regards,
Guru Prasad R
08-12-2007 10:25 PM
Hi Karim,
For Zterm, generally configure 9600 baud, 8 bits, no parity, 1 stop bit and you must select usbserial if you're using a usb-to-serial converter.
HTH,
Mohammed Mahmoud.
08-13-2007 01:20 AM
It shows to me as either Com3 or Com4
Narayan
08-13-2007 07:03 AM
thanks for the reply all of you, the issue that I have is where I can configure all this >>>>
Bits per sec : 9600
Data bits : 8
Parity : none
Stop bits : 1
Flow control : none
the Screen is blank so how I will configure it ..I do not see any options where I do that ..
08-13-2007 07:52 AM
I did some digging and here is one of the answers , have not try it yet , but will let you know . late on today.. Thank you all
08-13-2007 12:05 PM
Hi Karim,
As illustrated in the link you've found, first you need to go to settings -> Modem Preferences -> select usbserial0 as the default modem and then edit your connection parameters as said in earlier posts, and it should be that simple.
HTH,
Mohammed Mahmoud.
08-13-2007 05:44 PM
08-14-2007 12:39 PM
any one can help with this one please / Thanks
08-14-2007 12:59 PM
Hey Karim,
How do you do :), you'll need to make sure that you've installed the driver for the usb-to-serial converter.
HTH,
Mohammed Mahmoud.
08-14-2007 01:50 PM
Mo .. I did buy a generic usb/serial and it did not come w/ the driver... do I have to buy an other one// Thanks
08-14-2007 11:19 PM
Hi Karim,
HTH,
Mohammed Mahmoud.
08-19-2007 09:57 AM
Hi Mo
I did try to download the driver but I get a Chinese characters. I will try it again today... Tanks
08-20-2007 05:16 AM
That did it Mo .. thanks for taking your time to help me with the issue. it works better then windows hypererminal.. :-)
08-20-2007 05:49 AM
Hi Karim,
HTH,
Mohammed Mahmoud.
