09-20-2010 06:31 AM - edited 03-06-2019 01:04 PM
i have a cisco 877w router and configured a wired lan 10.10.10.0 vlan1 and via a bvi a wirelss lan 10.70.10.0
is it possible to make one vlan of them ?
jilles
09-21-2010 09:13 AM
This is possible if you make the wireless router a node on the 10.10.10.0 network and NAT the traffic from the 10.70.10.0 network to the 10.10.10.0 network (schema attached). Alternatively, you can put the wireless router into Wireless access point mode and it will act like a switch, no further config required (schema2 attached).
09-23-2010 10:44 AM
both networks are inside, the wan interface is the outsde
, how do i nat from inside to inside ?
09-23-2010 01:11 PM
Allow me to correct myself. I misread you initial question. You have two networks on the same router, correct?
In this case, you should be able to accomplish this. All you have to do is do configure the same vlan on the BVI and FastEthernet interfaces
Short config (some output omitted):
!---Wired---
interface FastEthernet0
switchport access vlan 10
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
!---Wireless---
interface Dot11Radio0
ssid SSID-name
vlan 10
