1042N AP wont connect to 2106 WLC
Hey all,
We recently purchased a bundle of 3 1042N AP's with a 2106 WLC. I am able to get the controller on the network and am able to manage it through the https web gui. I am now trying to add one of the AP's to the controller and am getting an infinite loop on the AP upon bootup. I tried looking up the solution but could not find a good article that pertained to the problem I was having. One thing I did notice is the time on the AP is way offset, but when I do a clock set to change it to the actual date it doesnt stick on the next reload.
Thanks in advance to anyone reading this.
Here is the output:
using ÿÿÿÿ ddr static values from serial eeprom
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x83000800, 0xc0000000
RQDC, RFDC : 0x80000037, 0x00000190
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 28 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 7108096
flashfs[0]: Bytes available: 25276928
flashfs[0]: flashfs fsck took 24 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: c4:64:13:11:28:36
Ethernet speed is 100 Mb - FULL duplex
Loading "flash:/c1140-k9w8-mx.124-23c.JA/c1140-k9w8-mx.124-23c.JA"...##########################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1140-k9w8-mx.124-23c.JA/c1140-k9w8-mx.124-23c.JA" uncompressed and installed, entry point: 0x4000
executing...
enet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1040 Software (C1140-K9W8-M), Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 01-Jun-10 12:29 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 28 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 7108096
flashfs[1]: Bytes available: 25018880
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Radio0  present 8363 8000 90020000 0 90030000 B
Radio1  present 8363 8000 98020000 0 98030000 0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1042N-A-K9    (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FTX1551K4A0
PowerPC405ex CPU at 333Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 7.0.98.0
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: C4:64:13:11:28:36
Part Number                          : 73-14034-04
PCA Assembly Number                  : 800-34273-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC15491WAJ
Top Assembly Part Number             : 800-34285-03
Top Assembly Serial Number           : FTX1551K4A0
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1042N-A-K9
% Please define a domain-name first.
Press RETURN to get started!
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 00:00:09.775: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:09.790: *** CRASH_LOG = YES
Security Core found.
Base Ethernet MAC address: C4:64:13:11:28:36
*Mar  1 00:00:11.197: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:11.763: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:11.836: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:11.863:  status of voice_diag_test from WLC is false
*Mar  1 00:00:12.890: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:13.961: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:14.020: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:14.021: %SNMP-5-COLDSTART: SNMP agent on host APc464.1311.2836 is undergoing a cold start
*Mar  1 00:12:14.082: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:12:14.082: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:12:15.082: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:12:15.082: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:12:26.077: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:12:26.079: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:12:26.634: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio0, Timed out waiting for fw to clear txp_pndg flag
*Mar  1 00:12:27.134: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Mar  1 00:12:27.488: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:12:32.896:  status of voice_diag_test from WLC is false
*Mar  1 00:13:00.715: %CDP_PD-4-POWER_OK: Full power - HIGH_POWER_CLASSIC_NOT_CONFIGURED inline power source
*Mar  1 00:13:00.751: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:13:00.760: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:13:01.730: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:13:01.730: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.10.200.50 started - CLI initiated
*Mar  1 00:13:01.752: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:16:50.982: %CAPWAP-5-STATIC_TO_DHCP_IP: Could not discover WLC using static IP. Forcing AP to use DHCP.
*Mar  1 00:17:04.004: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:17:14.004: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:17:24.004: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:17:34.004: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:17:44.004: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
Not in Bound state.
*EDIT*
Also I tried setting the capwap IP and everything to force it to find the WLC but it did not solve the problem.
APc464.1311.2836#show capwap ip config
LWAPP Static IP Configuration
IP Address         10.10.20.103
IP netmask         255.255.0.0
Default Gateway    10.10.0.1
Primary Controller 10.10.20.100
1 ACCEPTED SOLUTION
Interesting..your Virtual interface doesn't show an IP address.  Can you set an address on the virtual, reboot and then run the debugs again?
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Wats the WLC software version?? guess 1042 needs 7.0.98 and above i am right..
Surendra
The WLC Software version is 7.0.98.
run the below debug on the WLC and reboot the AP and paste the logs here..
debug capwap events enable
debug capwap errors enable
Surendra
On the controller I enabled the two debug commands you mentioned. Rebooted the AP and didnt see anything on the controller come up for debugging. Did this twice to make sure I didnt miss anything. I also did a show logging to make sure debugging output was enabled on the console level and it was.
How are you informing the AP of the WLC managemet address?  DHCP option 43, DNS of cisco-capwap-controller ?
Steve
Stephen,
Maybe that is where I am messing up. Its been a few years since I have configured WLC and APs so I may be missing a step.
On the controller tab on the web gui I have a DHCP scope set for the AP's and Enable DHCP proxy is checked. Am I missing something?
As a test I set a static IP on the AP so it could find the controller (see below). Is this not the best way to do things anymore?
I also put in a DNS entry of the Primary Controller's IP to cisco-capwap-controller on our internal DNS server. This still didnt solve anything although where on the AP do i set the DNS server for it to look at? I cant enter a global config mode because (from what ive read) its in lightweight mode and thats the correct mode for working with the controller.
For DNS to work, you would need to setup a DHCP scope to give the AP the server address.
As for the 'best' way, I wouldn't go with a static IP, I'd just use a DHCP scope and option 43 much easier to get everything up and running that way.  If the AP can't find the WLC with it's configured static, it will fall back to being DHCP anyway.  And during the first join, you would need to put the commands in with every reboot to be sure they were there, as you can't write to NV.
and on that note, can you post the output of show interface summary, as well as the port(s) the WLC is connected to, and the port the AP is on?
Steve
Ah, that makes sense.
Here are the outputs you requested:
(Cisco Controller) >show interface summary
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
ap-manager                       1    untagged 10.10.20.101    Static  Yes    No
management                       1    untagged 10.10.20.100    Static  No     No
test                             1    21       10.10.21.2      Dynamic No     No
virtual                          N/A  N/A      0.0.0.0         Static  No     No
Show int on WLC:
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... 70:81:05:af:15:e0
IP Address....................................... 10.10.20.100
IP Netmask....................................... 255.255.0.0
IP Gateway....................................... 10.10.0.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Physical Port.................................... 1
Primary DHCP Server.............................. 10.10.20.100
Secondary DHCP Server............................ 10.10.10.102
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
Show int on AP:
GigabitEthernet0 is up, line protocol is up
  Hardware is PowerPC405ex Ethernet, address is c464.1311.2836 (bia c464.1311.2836)
  Internet address is 10.10.20.103/16
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Full-duplex, 100Mb/s, media type is T
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:45, output 00:00:00, output hang never
  Input queue: 0/1677/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 0 bits/sec, 1 packets/sec
     3 packets input, 885 bytes, 0 no buffer
     Received 3 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 0 pause input
     180 packets output, 15696 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Steve
Wow how embarassing. Once I changed the IP on the Virtual Interface the AP connected just fine. The weird thing is I had to set that during the initial setup and put it to 1.1.1.1. Regardless, I put it back and now the AP is showing up in the Wireless tab on the WLC.
Thank you Stephen!
1121
