1130AG no signal
I have set up a 1130ag as an access point and the laptops (one xp and one vista) cannot find the SSID. If I manually add the SSID it works fine. The radio is enabled, the interface is up and I have tried manually switching channels without any luck. I am missing something somewhere. Any ideas?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: 1130AG no signal
Under the dot11radio 0 or dot11radio 1 enter:
guest-mode
That will broadcast the ssid if your ap is autonomous.
If you have a wlc, then under the wlan ssid, enable the checkbox for broadcast.
-Scott
guest-mode
-Scott
Perfect, I went into the SSID manager and had to specifically select the SSID under "Set Beacon Mode" and then it started working. Thanks!
Hall of Fame Super Gold
Is the SSID Broadcase disabled by any chance?
280
