1130AG Won't Hold Time And Date After A Reload
Hello - I am currently deploying 1130AG standalone access points to all my locations. I am having trouble getting them to consistantly authenticate against AD using RADIUS and PEAP. I have noticed that all the access points revert back to a date in 2001 or 2002 after every reboot. So, first, after I issue the clock set command and fix the time and save it, how do I get it to hold that after a reboot. And second, could the time/date mismatch be causing a problem with authentication? Here is a typical config that I am using:
no service pad
service password-encryption
hostname S064AP
enable secret XX
aaa new-model
aaa group server radius rad_eap
server 10.0.64.10 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
ip name-server 10.0.64.10
dot11 ssid S064WLAN
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
guest-mode
infrastructure-ssid optional
power inline negotiation prestandard source
username admin password XX
username Cisco privilege 15 password XX
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid S064WLAN
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.0.64.205 255.255.255.0
no ip route-cache
ip default-gateway 10.0.64.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
snmp-server community XX RW
radius-server host 10.0.64.10 auth-port 1645 acct-port 1646 key XX
bridge 1 route ip
line con 0
line vty 0 4
end
Gold
Re: 1130AG Won't Hold Time And Date After A Reload
Looks like you are running into bug CSCsq64212.
Hall of Fame Super Gold
You can enable SNTP to synchronize your clock.
Command: sntp server
168
