Community Member
1142 Access Points converting from Autonomous to LWAPP
Hello All,
I am trying to convert 5 1142 APs to LWAPP ... they came as Autonomous APs out of the box but the customer has decided to go the unified route so I need to convert them to complete the job.  I tried using the Upgrade tool ver 3.4 and it say that the 1142 AP is not supported by the Upgrade Tool
Is there an alternative way to do this??
Thanks in Advance!!!!
1 ACCEPTED SOLUTION
Community Member
Re: 1142 Access Points converting from Autonomous to LWAPP
console or SSH to your AP and enter the following command:
archive download-sw  tftp://x.x.x.y/c1140-rcvk9w8-tar.124-21a.JA.tar
x.x.x.y = address of your tftp server.
just like upgrading any newer Cisco device. Obviously you need a tftp server running, ect.,..
Best of luck to you.
Doug
1 REPLY
Community Member
Doug
6273
