1142 AP behaving differently to an 1130AP when on the same controller.
Hi there, I have a new WLC 2504 running  7.6.120.0, I have two AP's connected to it one is AIR-LAP1142N-E-K9 IOS Version 15.2(4)JB5$ the other is a AIR-LAP1131AG-E-K9 IOS Version 12.4(25e)JAO5$
When I try to connect to my SSID I have created I can connect to it fine when the 1131 is broadcasting the SSID, however if I disable that and enable the 1142 it cannot connect. I am at a loss to see what the issue is as the WLC should be doing the authentication for the AP's so the results should be the same.
On the console of the 1142 I get
*Oct  7 13:20:33.239: %LWAPP-3-CLIENT_ACL_ENTRY_NOT_EXIST: Deleting Mobile for 0026.c64f.30e2: CLIENT ACL not exist on AP
*Oct  7 13:20:34.565: %LWAPP-3-CLIENT_ACL_ENTRY_NOT_EXIST: Deleting Mobile for 0026.c64f.30e2: CLIENT ACL not exist on AP
*Oct  7 13:20:36.318: %LWAPP-3-CLIENT_ACL_ENTRY_NOT_EXIST: Deleting Mobile for 0026.c64f.30e2: CLIENT ACL not exist on AP
*Oct  7 13:20:37.881: %LWAPP-3-CLIENT_ACL_ENTRY_NOT_EXIST: Deleting Mobile for 0026.c64f.30e2: CLIENT ACL not exist on AP
Which I take to mean its not getting the downloadable ACL to it. As the 1131 works I am not sure what could be causing this. Any ideas?
Everyone's tags (1)
on the WLC can you rundeubg
deubg client < client mac address>
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Attached are both
Attached are both
In both debugs the client
In both debugs the client gets an access accept from the WLC, and should move to getting a DHCP address.  In the 1142 debug the client attempts to reassociate immediately.
what NIC and driver is your test client running? If you are using an Intel 7200 you should be on 16.
HTH,
Steve
Ok I have an Intel Wifi Link
Ok I have an Intel Wifi Link 5100 on the Test machine. I have upgraded that to the latest version of driver on the intel site and it exhibits the same issue.
128
