1142 AP not getting power from 2106 WLC
I have been facing problem with POE ports( port 7 and 8) in 2106 WLC. I have connected AP 1142 on port 7 of 2106 controller but it is not comming up.
Bewlo is the command output. Not sure why the port is in power off mode.
(Cisco Controller) >show port summ
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE
1  Normal  Forw Enable  Auto       100 Full   Up     Enable  N/A
2  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
3  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
4  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
5  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
6  Normal  Forw Enable  Auto       100 Full   Up     Enable  N/A
7  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
8  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
Re:1142 AP not getting power from 2106 WLC
Are you able to try and connect the LAPs to another PoE port on another device?
Sent from Cisco Technical Support Android App
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
yes, I have tried another working AP on the POE ports but it didn't get power. Why the POE status is power off? Via power injector it just work fine. Something is wrong with the POE ports not why WLC is not providing power to AP.
Hall of Fame Super Silver
Re: 1142 AP not getting power from 2106 WLC
Try to issue the following:
config port power all enable
-Scott
no success ;-(
Still the port are in power off state.
(Cisco Controller) >show port summary
7  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off) ----<<<<<<<<
8  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off) ----<<<<<<<<
Then your 2016 went bad.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
264
