1142N APs cannot join 4404 WLC in the same VLAN!!
10 Access Pointd 1142N setup on vlan 10 and the controller management is in vlan 10.
They get DHCP IP addreses from the controller itself!! I do not have another DHCP server.
Here is what I get wich debug capwap event and debug capwap packet
(Cisco Controller) >*spamReceiveTask: Jul 31 12:21:41.283: <<<<  Start of CAPWAP Packet  >>>>
*spamReceiveTask: Jul 31 12:21:41.283: CAPWAP Control mesg Recd from 10.128.186.104, Port 51743
*spamReceiveTask: Jul 31 12:21:41.283:          HLEN 4,   Radio ID 0,    WBID 1
*spamReceiveTask: Jul 31 12:21:41.283:          Msg Type   :   CAPWAP_DISCOVERY_REQUEST
*spamReceiveTask: Jul 31 12:21:41.283:          Msg Length : 73
*spamReceiveTask: Jul 31 12:21:41.283:          Msg SeqNum : 0
*spamReceiveTask: Jul 31 12:21:41.283:   Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamReceiveTask: Jul 31 12:21:41.283:          Discovery Type : CAPWAP_DISCOVERY_TYPE_UNKNOWN
*spamReceiveTask: Jul 31 12:21:41.283:   Type : CAPWAP_MSGELE_WTP_DESCRIPTOR, Length 40
*spamReceiveTask: Jul 31 12:21:41.283:          Maximum Radios Supported  : 0
*spamReceiveTask: Jul 31 12:21:41.283:          Radios in Use             : 0
*spamReceiveTask: Jul 31 12:21:41.283:          Encryption Capabilities   : 0x00 0x01
*spamReceiveTask: Jul 31 12:21:41.283:   Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamReceiveTask: Jul 31 12:21:41.283:          WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamReceiveTask: Jul 31 12:21:41.283:   Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamReceiveTask: Jul 31 12:21:41.283:          WTP Mac Type  : SPLIT_MAC
*spamReceiveTask: Jul 31 12:21:41.283:   Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
*spamReceiveTask: Jul 31 12:21:41.283:          Vendor Identifier  : 0x00409600
        IE            :   UNKNOWN IE 207
*spamReceiveTask: Jul 31 12:21:41.283:  IE Length     :   4
*spamReceiveTask: Jul 31 12:21:41.283:  Decode routine not available, Printing Hex Dump
*spamReceiveTask: Jul 31 12:21:41.283: 00000000: 01 00 00 01                                       ....
*spamReceiveTask: Jul 31 12:21:41.283: <<<<  End of CAPWAP Packet  >>>>
*spamReceiveTask: Jul 31 12:21:41.283: a4:93:4c:46:a1:4f Discovery Request from 10.128.186.104:51743
*spamReceiveTask: Jul 31 12:21:41.283: a4:93:4c:46:a1:4f Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 100, joined Aps =0
can you capture the below through two reboots of the AP:
debug capwap events enable
debug capwap errors enable
no need for capwap packet usually.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Salam Hosam,
Besides what Steve requested, if you can check the console output of the AP when it tries to join that will be also helpful.
What is the software version of your controller?
Do you have the AP manager interface on same VLAN as the management?
Are you utilizing LAG on the controller?
You have all the four ports of the WLC connected to the neighbor switch?
Thanks.
Amjad
Rating useful replies is more useful than saying "Thank you"
- My controller is 7.0.220.0
- I cannot console to AP becasue they are mounted above ceiling
- management: 192.126.0.100 and ap-manager is 192.168.0.101
- I'm not using LAG becase I have 1 port connect to the switch
Hall of Fame Super Gold
Can you please provide the following command outputs:
1.  WLC:  sh sysinfo;
2.  WAP:  sh version;
3.  WAP:  sh inventory
Does the time correct on WLC?
I'm using NTP and it is correct time on the box.
show sysinfo:
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.220.0
RTOS Version..................................... 7.0.220.0
Bootloader Version............................... 6.0.199.4
Emergency Image Version.......................... 6.0.199.4
Build Type....................................... DATA + WPS
System Name...................................... CO-LWAPP
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.3
IP Address....................................... 10.128.186.100
System Up Time................................... 1 days 18 hrs 5 mins 16 secs
System Timezone Location.........................
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +42 C
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ D0:D0:FD:35:BD:E0
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Absent
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 100
For test purpose i would try untag vlans 0 between wlc d Ap. Just to see if it get joined. Because i rember having this issue and i have to take it step by step.
Thanks for this.  Now where are the outputs to the following commands:
1.  WAP:  sh version;
2.  WAP:  sh inventory
696
