1142N radios won't turn on
Hello, Wifi Experts!
Received 20 1142N AP's
19 were registered and working with the Controller code version 7.3.101.
One was DOA so we had it RMA'd.
Replacement came, with same part number.
Plugged it in into the network.
Successfully registered to the controller.
BUT ITS RADIOS WON'T TURN ON!
802.11B/G was configured 'Enabled' but its status is 'Disabled'.
plugged it on a switch where one of the working AP's is connected.
switchport configs are identical for these two AP's.
and still the radios won't turn on.
Any birght ideas, experts!!!
Hall of Fame Super Silver
Re: 1142N radios won't turn on
Make sure the ap operational status is enabled. The radios being enabled are a different setting.
-Scott
Here is a screen shot. I would also recommend you have at least one ssid enabled.
-Scott
Thanks, Fella5!
Operational Status is 'Down'
Admin Status 'Enable'
SSID are configured already and working with other 19 AP's.
I'm able to access the wireless from other AP's.
This problem is only for the RMA'd AP.
Its radios won't come UP.
Hall of Fame Super Gold
Console into the AP and reboot the AP.
Post the entire bootup process.
Thanks, Leo, for your reply.
Here is the AP boot capture:
using  eeprom values
WRDTR,CLKTR: 0x87000800 0x40000000
RQDC ,RFDC : 0x80000036 0x00000208
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x87000800, 0x40000000
RQDC, RFDC : 0x80000036, 0x00000208
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 27 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 7427584
flashfs[0]: Bytes available: 24957440
flashfs[0]: flashfs fsck took 20 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 50:57:a8:7b:56:c9
Ethernet speed is 100 Mb - FULL duplex
Loading "flash:/c1140-k9w8-mx.124-23c.JA7/c1140-k9w8-mx.124-23c.JA7"...#########
File "flash:/c1140-k9w8-mx.124-23c.JA7/c1140-k9w8-mx.124-23c.JA7" uncompressed a
nd installed, entry point: 0x4000
executing...
enet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 12.4(23c)JA7, RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 29-Jan-13 05:08 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 27 files, 9 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 7427584
flashfs[1]: Bytes available: 24699392
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Radio0  present 8363 8000 90020000 0 90030000 B
Radio1  present 8363 8000 98020000 0 98030000 0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1142N-K-K9    (PowerPC405ex) processor (revision B0) with 98294K/32
768K bytes of memory.
Processor board ID FGL1611S3CW
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 7.0.240.0
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 50:57:A8:7B:56:C9
Part Number                          : 73-12836-04
PCA Assembly Number                  : 800-33767-04
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16083D27
Top Assembly Part Number             : 800-33775-03
Top Assembly Serial Number           : FGL1611S3CW
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1142N-K-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:0crypt on interface Dot11Radio 0 -Process= "Init", ipl= 0, pid= 3
*Mar  1 00:00:09.975: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 1
*Mar  1 00:00:10.016: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log
(contains, 1017 messages)
*Mar  1 00:00:10.039:  status of voice_diag_test from WLC is false
*Mar  1 00:00:11.080: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state
to up
*Mar  1 00:00:12.158: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0, changed state to up
*Mar  1 00:00:12.194: %SYS-5-RESTART: System restarted --
SOFTWARE (fc1)
*Mar  1 00:00:12.194: %SNMP-5-COLDSTART: SNMP agent on host AP5057.a87b.56c9 is
undergoing a cold start
*Mar  1 00:00:12.246: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:12.310: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Mar  1 00:00:12.310: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar  1 00:00:13.310: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
1, changed state to down
0, changed state to down
*Mar  1 00:00:13.500: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:21.309: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigne
d DHCP address 192.168.1.52, mask 255.255.255.0, hostname AP5057.a87b.56c9
*Mar  1 00:00:31.121:  status of voice_diag_test from WLC is false
*Mar  1 00:00:31.181: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:31.214: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power s
ource
*Mar  1 00:00:31.238: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:32.222: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:00:32.222: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.
255 started - CLI initiated
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Aug 25 08:18:04.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
p: 192.168.1.2 peer_port: 5246
*Aug 25 08:18:05.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
wmmAC status is FALSE
*Aug 25 08:18:06.031: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
peer_ip: 192.168.1.2 peer_port: 5246
*Aug 25 08:18:06.031: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Aug 25 08:18:06.031: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Aug 25 08:18:06.167: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Aug 25 08:18:07.431: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Aug 25 08:18:07.475: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller Cisco
_9a:8e:00
*Aug 25 08:18:07.518: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to a
dministratively down
*Aug 25 08:18:07.519: %LWAPP-3-CLIENTEVENTLOG: SSID test added to the slot[0]
*Aug 25 08:18:07.522: %LWAPP-3-CLIENTEVENTLOG: SSID test added to the slot[1]
*Aug 25 08:18:07.534: %WIDS-5-ENABLED: IDS Signature is loaded and enabled
*Aug 25 08:18:08.517: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
User Access Verification
Username: Cisco
Password:
AP5057.a87b.56c9>en
Password:
% Access denied
AP5057.a87b.56c9>en
Password:
AP5057.a87b.56c9#
AP5057.a87b.56c9#
AP5057.a87b.56c9#
AP5057.a87b.56c9#sh ip int brie
Interface                  IP-Address      OK? Method Status                Prot
ocol
Dot11Radio0                unassigned      NO  unset  reset                 down
Dot11Radio1                unassigned      NO  unset  administratively down down
GigabitEthernet0           192.168.1.52    YES DHCP   up                    up
AP5057.a87b.56c9#
Hmmmm ...
Can you post the output to the WLC command "sh sysinfo".
I have a strange feeling your AP has the wrong regulatory domain and this is why 802.11b radio is disabled.
Your AP model number is "AIR-LAP1142N-K-K9" and with the regulatory domain of South Korea and your name doesn't sound South Korean.
Do you have a WLC?
If you do, post the output to the WLC command "sh sysinfo".
sent as PM...
Configured Country............................... SA  - Saudi Arabia
As I've suspected.
Your WLC is configured for Saudi Arabia (regulatory domain "-E") but your AP is for South Korea.
What country will this AP be installed?
SA
If both the AP & WLC is are to be installed in KSA, then contact the vendor who sold you the AP and politely ask them to change the AP with the one with the correct regulatory domain, "-E".
Thanks, Leo!
Will escalate this issue.
But howcome, all the other 19 access points are working and this one doesn't?
Using the WLC, look at the regulatory domain of the APs.  For KSA, they should be "-E".  Maybe this one AP was delivered to you in error.
AP's bg RD is -E and a RD is -K
WLC CC is set SA
at least the 2.4 should work for this AP, right?
they prolly sold this here since 5GHz will not work if WLC's CC is set to SA.
You need to make sure the country code is also set on the WLC. Might require a reboot also. With multiple country codes, the WLC will only allow the common channels for all countries defined. Since you didn't add all the country codes for your access point, the controller is disabling the radios.
-Scott
Hello, Fella5!
Thanks for your reply.
Is the following correct?
this is the current setting now.
after the wlc reboot, both radios are still down.
Well I think you will have to be creative here unless you just tam that one also. I would and have in the past have to delete all the images in flash on the access point and the tftp a new recovery image to the AP and then also erase the nvram. After this process the ap should be like new in the box. This has fixed issues with me since I test a lot of beta code and APs tend to fail from upgrades.
On the AP you need to console and get into the ap. Issue a
debug capwap console cli
debug capwap client no-reload
erase /all nvram
dir
archive download-sw/overwrite/force-reload tftp:////
AP#archive download-sw /force-reload /overwrite tftp://10.0.0.5/c1140-rcvk9w8-tar.124-23c.JA.tar
reboot without saving
-Scott
Hello, Fella5!
Thank you for your reply!!!
That was also my last resort to tftp this ap with a new code.
What is Mini IOS? because i found a huge version difference between the AP's
Kindly, see below.
736
