1142N VLAN configuration issue
     I have a Cisco 1142N dual-band WAP that is 95% configured.  It currently has 2 SSIDs which are broadcasting and tagging the traffic for the correct VLANs.  I have configured most of the settings from the web interface.  However, when I go to add the Radio1-802.11N to either of the SSIDs, I recieve the following message "VLAN '3' doesn't exist on 'Radio1-802.11N 5GHz' (see Services>VLAN)"  However, when I go to Services>VLAN Both radios are tagged for both VLANs, so my question is are both VLANs tied to both radios?  If not, how can I configure it?  I don't know the console commands would be for those.  Any help would be greatly appriciated.
Adam
ap#show running-config
Building configuration...
Current configuration : 3304 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret
no aaa new-model
dot11 syslog
dot11 vlan-name GuestWireless vlan 3
dot11 vlan-name WGSWhitecaps vlan 1
dot11 ssid Whitecaps Guest
   vlan 3
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 0204015A080E0D3441
dot11 ssid Whitecaps Owner
   vlan 1
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 08334342050D0C1317
username Cisco password 7 00271A150754
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
encryption vlan 1 mode ciphers aes-ccm tkip
encryption vlan 3 mode ciphers aes-ccm tkip
antenna gain 0
mbssid
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
antenna gain 0
dfs band 3 block
speed  basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface Dot11Radio1.3
no ip route-cache
bridge-group 3
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.3
no ip route-cache
bridge-group 3
interface BVI1
ip address 10.10.199.3 255.255.255.0
no ip route-cache
ip default-gateway 10.10.199.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Re: 1142N VLAN configuration issue
Adam:
Your WLANs are not configured under the radio 802.11a. (Dot11Radio1). They are only configured under radio 802.11b/g.
The folloing commands appear under interface Dot11Radio0. You need to add them under interface Dot11Radio1 as well:
Amjad
Rating useful replies is more useful than saying "Thank you"
Bronze
The configuration looks to be okay
The only thing is that as mention above, if you want to use the A radio to add the ssid under the interface.
Also i noticed that you have configured to use both encryption ciphers AES and TKIP and this may or may not work if the wireless client supports it or could create connectivity issues and at the end you have wireless clients reporting that they connect and disconnect.
As per the WiFi alliance when working with wpa version 1 we use the cipher of TKIP and when working with WPA version 2 we use the cipher of AES-CCM and due to this all wireless clients are set to comply with the WiFi alliance so the wireless card can do an encryption method at a time either wpav1 + TKIP or wpav2 + AES.
Also make sure that the switch where the ap is connected is configured as a trunk port with the same untagged or natvie vlan the access point has an ip address for.
2063
