Community Member
1200: Native VLAN & Management VLAN
I want to keep the management VLAN and native VLAN seperate. Is this the correct setup when using VLAN 999 as the native VLAN and VLAN 100 for the management VLAN.
Management VLAN 100 (10.100.0.0/24)
### Trunk SW ###
description "AP"
switchport trunk native vlan 999
switchport trunk allowed vlan
switchport mode trunk
switchport nonegotiate
speed 100
duplex full
### AP ###
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 99 key 1 size 128bit 7 3831CB248113D952741376BEC352 transmit-key
encryption vlan 99 mode wep mandatory
encryption vlan 11 mode ciphers tkip
ssid xoxoxo
vlan 11
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
ssid xxx
vlan 99
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
rts threshold 2312
station-role root
interface Dot11Radio0.11
encapsulation dot1Q 11
no ip route-cache
bridge-group 11
bridge-group 11 subscriber-loop-control
bridge-group 11 block-unknown-source
no bridge-group 11 source-learning
no bridge-group 11 unicast-flooding
bridge-group 11 spanning-disabled
interface Dot11Radio0.99
encapsulation dot1Q 99
no ip route-cache
bridge-group 99
bridge-group 99 subscriber-loop-control
bridge-group 99 block-unknown-source
no bridge-group 99 source-learning
no bridge-group 99 unicast-flooding
bridge-group 99 spanning-disabled
interface dot11radio 0.999
encapsulation dot1q 999 native
interface dot11radio 0.100
encapsulation dot1q 100
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
ntp broadcast client
interface FastEthernet0.11
no ip route-cache
bridge-group 11
interface FastEthernet0.99
no ip route-cache
bridge-group 99
interface fastethernet 0.999
interface fastethernet 0.100
interface BVI100
ip address 10.100.0.110 255.255.255.0
no ip route-cache
ip default-gateway 10.100.0.1
1 REPLY
Community Member
Re: 1200: Native VLAN & Management VLAN
This looks correct to me. Do you have a non_root bridge on their other side?
Are you able to trunk all 4 VLANS with this config?
302
