1240 AP does not honor native vlan diffent then 1
I stumple with a cracy issue and hope someone have an idea what is going wrong.
I have an older 1240 Autonomous AP where I cannot figure out why the device is using vlan1 instead the required vlan 1616 for management traffic.
Anyway clients can connect, getting IP adresses and traffic is routed but the ap can be managed only via serial console cable or temp. by configuring
the port on the 3750 from trunk to an access port.
1240 config.
version 12.4
hostname ap
dot11 mbssid
dot11 ssid vlan1621
   vlan 1621
dot11 ssid vlan1630
   vlan 1630
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 1621 mode ciphers aes-ccm
 encryption vlan 1630 mode ciphers aes-ccm tkip
 ssid vlan1621
 ssid vlan1630
 station-role root
 no cdp enable
interface Dot11Radio0.21
 encapsulation dot1Q 1621
 no ip route-cache
 bridge-group 21
interface Dot11Radio0.30
 encapsulation dot1Q 1630
 no ip route-cache
 bridge-group 30
interface FastEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
interface FastEthernet0.16
 encapsulation dot1Q 1616 native
 no ip route-cache
 bridge-group 1
interface FastEthernet0.21
 no ip route-cache
 bridge-group 21
interface FastEthernet0.30
 no ip route-cache
 bridge-group 30
interface BVI1
 ip address 192.168.16.11 255.255.255.0
 ip helper-address 192.168.18.20
 no ip route-cache
ip default-gateway 192.168.16.1
bridge 1 route ip
3750g config:
interface GigabitEthernet1/0/39
 switchport trunk native vlan 1616
 switchport trunk allowed vlan 1616-1630
 switchport mode trunk
 switchport nonegotiate
Changing the bridge-group on the fa0.16 subinterface from 1 to anything different was also without success.
tested 1240 firmware: c1240-k9w7- 123-8.JA2 / 124-25d.JA1 / 124-25d.JA2
VIP Purple
Autonomous AP management
Autonomous AP management always should be on a un-tagged vlan. Management can be on vlan 1616, but you cannot tag that vlan.
That's why you have to use always "bridge-group 1" command under sub-interface configured for management (fa0.16 in this case) where you use "native" key word in dot1q configuration.
With the given configuration can you ping 192.168.16.1 from your AP ?
Rasika
**** Pls rate all useful responses ****
Hi Rasika,no, ping 192.168.16
Hi Rasika,
no, ping 192.168.16.1 or ping 192.168.16.1 source bvi1is not working.
VIP Purple
HiI have applied your config
I have applied your config onto 1252 AP directly connect to 3560 switch as shown below & config works as expected.
+++++++ Switch Config ++++++
vlan 1616,1621,1630
interface GigabitEthernet0/1
interface Vlan1616
 ip address 192.168.16.1 255.255.255.0
++++++++++ AP Config ++++++++++
dot11 ssid vlan1621
   vlan 1621
dot11 ssid vlan1630
   vlan 1630
 ssid vlan1621
 ssid vlan1630
 bridge-group 21
 bridge-group 30
interface GigabitEthernet0.16
 bridge-group 1
interface GigabitEthernet0.21
 bridge-group 21
interface GigabitEthernet0.30
 bridge-group 30
interface BVI1
AAP1#ping 192.168.16.1
Sending 5, 100-byte ICMP Echos to 192.168.16.1, timeout is 2 seconds:
If it does not work for you, I would check vlan 1616 is available in all your switches upto where SVI for vlan 1616 defined.
In your case interface vlan 1616 defined on AP directly connected switch ?
Rasika
**** Pls rate all useful resposnes ****
Hi Rasika,after going line by
Hi Rasika,
after going line by line over the switch config I found the culprit.
On the client access stack the following parameter was set
vlan dot1q tag native
removing the line and everything started to work.
Anyway I think Native Vlan Tagging is quite useful on client access switches.
The following port configuration on the stack was also working but not stable, after some time packes where dropped so it is no solution.
! not stable workaround for WAP if param. "vlan dot1q tag native" is set on the stack
 switchport access vlan 1616
 switchport trunk native vlan 999
Is there a possible working solution with "Native Vlan Tagging" and Wireless ?
olli
VIP Purple
Hi Great, you found the issue
Great, you found the issue & fixed it.
In AP, there is no way to get management working with tag vlan.
Rasika
Strange, I got your reply and
Strange, I got your reply and see it until I'm logged in ...
Yes vlan1616 is aviable on that stack, indeed there is a second backup server in vlan1616 connected to this stack.
Will post the relevant stack config later if I'm back in the office
30
