1240ag Bridge Issue
I have 2 1240ag's 1 in root bridge mode and the other setup as workgroup bridge.  I am bridging the main building with another building.  It is working, but I can only ping from the wgb location.
Re: 1240ag Bridge Issue
Hi, if they are associated they have to work like this, don't you have some issues with firewall or some thing like that? if not, can you post the config of the two ap's and the show dot11 associations for both?
Best Regards,
Milton Tizoc.
Hall of Fame Super Silver
You should try to setup one end as an access point and the other as a WGB.  Or else just do root-bridge to non-bridge if the remote end is going to be connected to a switch.  If you do the later, you can do the bridge link on one band and setup the other band for wireless access also.
-Scott
426
