1242 AP (FAT) with AIR-ANT2506 Antenna & AIR-CAB050LL-R Cable
I am planning to have FAT access point 1242 connected to AIR-ANT2506 external Antenna.
Are these two things compatible?
Secondly, AP and Antenna will be 230 feet away, hence I am planning to buy a cable from Cisco (Part Code AIR-CAB050LL-R)
Is this antenna and cable compatible with each other?
  • Getting Started with Wireless
1 REPLY
Bronze
Hi ,
You can check the information of the antenna under the Cisco antenna reference guide, and if the AP 1242 you have has a 2.4GHZ or G radio then the antenna will work since it is 2.4GHZ compatible.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
The cable AIR-CAB050LL-R should also work with the antenna you have.
707
