Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
1242 downgrade process fails - why?
I am attempting to downgrade(?) a LWAPP 1242 model device. We need it to be autonomous until such time, a Controller can be introduced into the environment. We have no IOS version AP's on-hand, so this is a must-do process.
I have accessed the instructions that discuss pressing the MODE button, etc. The ESC button has no affect whatsoever during flash initialization - I never see the [ ap: ] prompt. Have tried multiple versions, including over 60 seconds of holding MODE down when unplugging and plugging power cable back in.
I am statically connected to the AP using 10.0.0.x range, as directed and TFTP Server is running with appropriate file downloaded and renamed per instructions. The MODE process does prompt for accessing TFTP server - but process simply times out and runs back to existing flash file.
As instructed, I press MODE and then after reboot attempt to access a webpage inside the device - it is still LWAPP - and nothing is accessible. Your instructions appear misleading.
http://www.cisco.com/en/US/partner/docs/wireless/access_point/12.2_15_JA/configuration/guide/s15trb.html#wp1048727
Would appreciate advice on how to access [ ap: ] only mode on 1242 model access point.
Suggestions?
Re: 1242 downgrade process fails - why?
I did see one error on my part - it states the file must be 123(7)JA, or earlier. We are retesting now...
This process, as you've outlined it on your website, simply will not work for me. The boot process of holding MODE button in until light goes RED, does allow for recovery option and it does access my TFTP Server (Solarwinds ver 9) looking for the 're-named' file, as per instructions.
However, it simply times out and reverts to loading the original LWAPP file, as opposed to loading the renamed autonomous file we would prefer.
AP has IP address of 10.0.0.1 255.0.0.0
Default-gateweay of 10.0.0.254
PC/TFTPserver using 10.0.0.2 255.0.0.0
PC Default gateway 10.0.0.254
This should be as simple as it ever gets.
I'm using the default version of hyperterm that comes with Windows XP.
TFTP Server is activated and started.
Root Directory: C:\TFTP-Root
Every action handled as Admin on the PC.
Got any ideas?
Perhaps you missed the line in the documentation that reads:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Hall of Fame Super Silver
Or your FW is blocking TFTP. After holding the mode button down for about 20 seconds, you should see something on the console that say's mode button pressed, that is when you release the mode button.
Post you log so we can see where it fails.
-Scott
Hall of Fame Super Gold
Try the following:
1. Connect the LAP to the same LAN as the TFTP server.
2. Give the AP an IP Address: lwapp ap ip address
3. From the LAP, ping the TFTP server
4. Copy the Autonomous IOS from the TFTP server to your AP.
5. Delete the LWAP IOS from the AP: delete /f /r flash:RCV prefix>
6. Boot the AP into Autonomous mode.
Hope this helps.
connect AP to PC directly (necessarily!!!)
552
