1242 is not joining controller
hello friends,
i have 1240 series access points which is not joining controller 5500 series..
here is logs at joining time below
AP503d.e56e.e7be#Xmodem file system is available.
flashfs[0]: 7 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 2649600
flashfs[0]: Bytes available: 13349376
flashfs[0]: flashfs fsck took 25 seconds.
Base ethernet MAC Address: 50:3d:e5:6e:e7:be
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
button is pressed, wait for button to be released...
button pressed for 37 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/c1240-k9w7-tar.default
examining image...
%Error opening  (connection timed out)Loading "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx"...#############################################################################################################################################
File "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.4(21a)JA2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 02-Nov-09 18:40 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 6 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 2632192
flashfs[1]: Bytes available: 13366784
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1242AG-E-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCZ150482DL
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 50:3D:E5:6E:E7:BE
Part Number                          : 73-10256-07
PCA Assembly Number                  : 800-26918-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC150158MH
Top Assembly Part Number             : 800-29152-03
Top Assembly Serial Number           : FCZ150482DL
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1242AG-E-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:05.426: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 34 messages)
*Mar  1 00:00:07.500: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:07.526: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:07.601: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:08.500: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar  1 00:00:12.979: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
AP503d.e56e.e7be#
*Mar  1 00:00:46.445: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
AP503d.e56e.e7be#
AP503d.e56e.e7be#
AP503d.e56e.e7be#sh ver
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
AP503d.e56e.e7be uptime is 0 minutes
System image file is "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx"
export@cisco.com.
--More--
*Mar  1 00:00:56.445: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not haveTop Revision Number                  : A0
Configuration register is 0xF
AP503d.e56e.e7be#
*Mar  1 00:01:06.445: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
any advice please??
thanks
Everyone's tags (2)
It look like your IP does not have an IP address. You can add an IP address from CLI or web base.
thanks for you r reply Chieu
i did that all
assign static ip to ap than gw and than also controller's ip
but when reboot ap it does not join the controller
an idea plz?
Can you ping the AP from the controller and ping the controller from AP? do show cdp neighbors detail to find the AP on the controller. Make sure both AP and controller on the same VLAN.
yes both are on the same vlan
but i can't ping also to each other
but i did't check cdp neigh det
thanks
Re: 1242 is not joining controller
Looking at the log file, I think you have a bad image on the AP
You might need to reimage it.
Bronze
It sounds like you are still working out IP connectivity, but I also noticed your AP is not for US regulatory domain.
Can you confirm that your WLC is ready to accept an AP with country code -E?
Your AP model:  AIR-LAP1242AG-E-K9
From the WLC CLI
>show country
If you are in US, you should only have -A available.  If this AP is intended to be used the US, then you will need to acquire an AP with the correct country code, as -E would not be supported in the US -A regulatory domain and should not be used.  Perhaps this is for another location, so you may need to add the applicable regulatory domain support.
This link provides the list of the respective country codes and compatbility/etc.
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5861/product_data_sheet0900aecd80537b6a_ps6087_Products_Data_Sheet.html
yes i am not in U.S
and model of ap is
AIR-LAP1242AG-E-K9
i have some other ap too that are all working fine with the same controller
and i have configured country code on controller too
thanks
Hello Waseem,
So when you run show cdp neighbors detail , can you see that your AP has IP address?
When you do the ping from the AP console to any other resource, example default gateway what is the result ? Do you receive any message like protocol not enabled ( configured  or allowed ) on the CLI ?
What is the ip address of the controller management interface?
Can you provide the output of
show capwap client config
show capwap client rcb
after making sure that your AP has valid ip address.
Dears,
I also face same problem like waseemfarrakh. But If I put Static IP + Controller IP i can ping controller IP....and I can Browse.
I didn't get IP from DHCP. always get this error
*Mar  1 00:01:07.220: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
Hall of Fame Super Silver
So are you saying it works when you put a static address but not when you have the ap setup for dhcp?
-Scott
right...
I connected to AP and it shows below error continues..
Hall of Fame Super Gold
Hi Usman,
As what Scott and David is asking you, when you MANUALLY configure the IP address on the WAP, it will join the controller?
If the answer is YES, then I'd say that I think you are mistaken.  Y'know why?
If the WAP has successfully joined the controller previously, then WHY is the WAP still booting up an "RCV" image?
Next, OK, granted that when you configure the IP address and the WAP rejoins the controller.  But the static IP address IS NOT saved so when you reboot the WAP, it doesn't have an IP address.
2042
