1242AG LAP not joining vWLC
LAP: 1242AG version 12.3(7)JX3
WLC: CTVM version 7.6.100.0
LAP IP: 192.168.3.11
WLC IP: 192.168.2.22
Followed directions on
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/99948-lap-notjoin-wlc-tshoot.html
1) Verified LAP and WLC can ping each other.
2) Verified that time on WLC is correct:
(Cisco Controller) >show time
Time............................................. Mon Mar  3 22:46:40 2014
3) Verified MIC on LAP is NOT expired:
Certificate
  Status: Available
  Certificate Serial Number: 4CD884DD0000000B2182
  Certificate Usage: General Purpose
  Issuer:
    cn=Cisco Manufacturing CA
    o=Cisco Systems
  Subject:
    ea=support@cisco.com
    cn=C1240-00175a9b08a4
    o=Cisco Systems
    l=San Jose
    st=California
    c=US
  CRL Distribution Point:
    http://www.cisco.com/security/pki/crl/cmca.crl
  Validity Date:
    start date: 05:02:38 UTC Apr 4 2006
    end   date: 05:12:38 UTC Apr 4 2016
    renew date: 00:00:00 UTC Jan 1 1970
  Associated Trustpoints: Cisco_IOS_MIC_cert
4) Getting the following messages on WLC.  (00:17:0f:20:c4:30 is the LAP)
*spamApTask0: Mar 03 22:45:39.885: 00:17:0f:20:c4:30 Received LWAPP DISCOVERY REQUEST to 00:0c:29:9e:17:d7 on port '1'
*spamApTask0: Mar 03 22:45:39.885: 00:17:0f:20:c4:30 LWAPP Discovery Request AP Software Version: 0x3027415
*spamApTask0: Mar 03 22:45:39.885: 00:17:0f:20:c4:30 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 200,joined Aps =0
*spamApTask0: Mar 03 22:45:39.885: 00:17:0f:20:c4:30 Received a Discovery Request from 00:17:0F:20:C4:30 destined for a different controller (0.0.0.0)!. Dropping the packet
5) Getting the following messages on LAP:
*Mar  1 00:15:50.797: LWAPP_CLIENT_EVENT: spamResolveStaticGateway  - gateway found
*Mar  1 00:16:00.805: %DOT11-6-FREQ_USED: Interface Dot11Radio0, frequency 2437 selected
*Mar  1 00:16:00.812: %DOT11-6-FREQ_USED: Interface Dot11Radio1, frequency 5765 selected
*Mar  1 00:16:00.812: LWAPP_CLIENT_EVENT: spamHandleDiscoveryTimer: Could not discover any MWAR
"show run-config" from vWLC attached.  How shall I troubleshoot?
Thank you!
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: 1242AG LAP not joining vWLC
I've never seen an old IOS like that before.
I would strongly recommend you upgrade the RCV file.  Before you can do that you need to convert this AP to autonomous and convert to controller-based IOS.  The fastest way to convert the AP to autonomous is to use this process:
Using a TFTP Server to Return to a Previous Release
Cisco IOS Software, C1240 Software (C1240-K9W8-M), Version 12.3(7)JX3, RELEASE SOFTWARE (fc1)
Wow.  That is a very, very old Aironet IOS.  What firmware was the controller running?  3.X?
Re: 1412AG LAP not joining vWLC
What is the country code configured on the vWLC and what is the Regulatory Domain of your AP (post the COMPLETE output to the command "sh version").
From LAP:
AP0017.5a9b.08a4#sh ver
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 28-Feb-06 21:32 by kellythw
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.3(7)JA1, RELEASE SOFTWARE (fc1)
AP0017.5a9b.08a4 uptime is 46 minutes
System image file is "flash:/c1240-k9w8-mx.123-7.JX3/c1240-k9w8-mx.123-7.JX3"
cisco AIR-LAP1242AG-A-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FTX1014B0RD
PowerPCElvis CPU at 266Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:17:5A:9B:08:A4
Part Number                          : 73-9925-04
PCA Assembly Number                  : 800-26579-04
PCA Revision Number                  : A0
PCB Serial Number                    : FOC10130VCR
Top Assembly Part Number             : 800-26804-02
Top Assembly Serial Number           : FTX1014B0RD
Top Revision Number                  : B0
Product/Model Number                 : AIR-LAP1242AG-A-K9
Configuration register is 0xF
AP0017.5a9b.08a4#
From vWLC:
Configured Country............................... US  - United States
Ok.  Country code and regulatory domain match.
Console into the AP and, in enable mode, enter this command "capwap ap controller ip address 192.168.2.22"
AP0017.5a9b.08a4#capwap ap controller ip address 192.168.2.22
% Invalid input detected at '^' marker.
AP0017.5a9b.08a4#
Exec commands:
  cd               Change current directory
  clear            Reset functions
  clock            Manage the system clock
  crypto           Encryption related commands.
  debug            Debugging functions (see also 'undebug')
  delete           Delete a file
  dir              List files on a filesystem
  disable          Turn off privileged commands
  dot11            IEEE 802.11 commands
  enable           Turn on privileged commands
  exit             Exit from the EXEC
  fsck             Fsck a filesystem
  help             Description of the interactive help system
  led              LED functions
  lock             Lock the terminal
  login            Log in as a particular user
  logout           Exit from the EXEC
  mkdir            Create new directory
  monitor          Monitoring different system events
  more             Display the contents of a file
  name-connection  Name an existing network connection
  no               Disable debugging functions
  ping             Send echo messages
  pwd              Display current working directory
  release          Release a resource
  reload           Halt and perform a cold restart
  rename           Rename a file
  renew            Renew a resource
  rmdir            Remove existing directory
  save             Start to save raise_interrupt_level stack
  send             Send a message to other tty lines
  set              Set system parameter (not config)
  show             Show running system information
  systat           Display information about terminal lines
  terminal         Set terminal line parameters
  test             Test subsystems, memory, and interfaces
  traceroute       Trace route to destination
  undebug          Disable debugging functions (see also 'debug')
  upgrade          Upgrade software
  verify           Verify a file
  where            List active connections
AP0017.5a9b.08a4#
From LAP:
AP0017.5a9b.08a4#ping 192.168.2.22
Sending 5, 100-byte ICMP Echos to 192.168.2.22, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
AP0017.5a9b.08a4#
From vWLC:
(Cisco Controller) >ping 192.168.3.11
Send count=3, Receive count=6 from 192.168.3.11
Post the output to the command "sh version".
AP0017.5a9b.08a4 uptime is 1 hour, 5 minutes
2 802.11 Radio(s)
AP0017.5a9b.08a4#
Thanks for the suggestion.  Upgrade fixed the problem.
Just out of curiosity, why can't we just upgrade to a newer LAP version?  Why do we need to convert to autonomous first?
Thanks again!
This is because the AP is running a very, very old full IOS.  I am suspecting it could be an Aerospace 2.X firmware.  I've never played with this old firmware so there are some commands to upgrade the IOS directly is even possible.
This is why I asked you to convert to autonomous first before converting to a higher CAPWAP version.
May I ask if you can mark this thread as "Answered"?
Hall of Fame Super Silver
Just to add... If you search the forum or look at the vWLC, it will say that you need to first join the AP to a WLC that is running v7.3 code in order for it to join a vWLC. The workaround is to upload the latest RCV image for the access point.
c1240-rcvk9w8-tar.124-25e.JAO3.tar
http://software.cisco.com/download/release.html?mdfid=280237322&flowid=7588&softwareid=280775090&release=12.4.25e-JAO3&relind=AVAILABLE&rellifecycle=ED&reltype=latest
-Scott
358
