1252 g/n Module
Can I use 2 g/n modules on one 1252 AP instead of using one 802.11a.
Hall of Fame Super Red
Re: 1252 g/n Module
Hi Murat,
This is not a supported configuration :)
You cannot use two of the same radio Modules.
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6973/ps8382/product_data_sheet0900aecd806b7c6d.html
Hope this helps!
Rob
Re: 1252 g/n Module
Thanks Rob.
In my Country we are not supported to use 802.11a. So dual radios is no means to us :). I gived a try :)
Murat
Re: 1252 g/n Module
Hi Murat,
You are most welcome my friend! Why not order the 1252 with the single module to save some $$;
AIR-AP1252G-x-K9
AIR-LAP1252G-x-K9
With single radio Module;
AIR-RM1252G-A-K9
From the doc I linked above.
Hope this helps!
Rob
Re: 1252 g/n Module
Hi Rob,
I am ordering single radio ones for 1242, 1131, 1252 series for our customers.
It saves great amount of $ when we ordered high quantity of products.
Murat
Re: 1252 g/n Module
Hey Murat,
Great thinking my friend! It's always an excellent practice to save the client money whenever possible. This really helps to build the ongoing relationship.
Cheers!
Rob
150
