1310 ethernet initialization problem
hi buddies,
i got one bridge from my other branch and it is running in rommon mode, when i write boot command it will start working, as i reboot this it will again goes in rommon mode. i think i need to upload a new IOS, so i format the flash and later on i find this error. when it boots
Xmodem file system is available.
flashfs[0]: 1 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 1536
flashfs[0]: Bytes available: 7739904
flashfs[0]: flashfs fsck took 12 seconds.
Base ethernet MAC Address: 00:17:59:18:a6:14
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
Reset done!
auto-negotiation takes 10000 milli-seconds to complete
ERROR: timeout waiting for auto-negotiation to complete
ERROR: fail to bring ethernet link up
The system has been encountered an error initializing
ethernet port. You may need to check hardware
The system is ignoring the error and continuing boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet, tftp, and finish
loading the operating system software:
ether_init
tftp_init
boot
The system is unable to boot automatically because there
are no bootable files to boot.
C1310 Boot Loader (C1310-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE (fc1)
Compiled Mon 13-Jun-05 15:39 by ssearch
plz help, its urgent.
Silver
Re: 1310 ethernet initialization problem
Follow the trouble shooting guide for the Access point, it may help you
http://www.cisco.com/en/US/docs/wireless/access_point/1300/installation/guide/130h_c5.html
i am able to upload an image through Xmodem but i am not able to xtract it.
is there any way to upload an image through Xmodem and i can xtract it.
ethernet is not initializing is it a hardware problem?
Regards.
Hall of Fame Super Gold
The IOS may be missing or corrupt from the AP. You'll need to upload the IOS (.bin filename extension) via XMODEM or TFTPDNLD (if this command is available).
745
