1532 AP/2504 controller
We have just purchased some new 1532I AP's when they are connected, (the same way as a 3602) they will not associate with our 2504 controllers!
The 1532 blinks red/green/amber as if there is insufficent power but that is not the case
the log from the AP shows it cycling thorugh some of our 2504's
*Mar  1 00:24:20.847: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'xxxxxxxxxxxxx'running version 7.3.101.0 is rejected.
*Mar  1 00:24:20.847: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:24:20.847: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:24:20.847: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:24:20.847: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from xxx.xxx.xxx.xxx
your help will be apreciated.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: 1532 AP/2504 controller
John,
Get the MAC address of the 1532 and add that to the Mac filter list
http://www.cisco.com/en/US/docs/wireless/technology/mesh/7.4/design/guide/mesh74_chapter_0101.html#ID4807
-Scott
You need v7.6 for that AP
Per your log:
-Scott
Under software requirements
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps12831/guide-c07-729725.html
-Scott
How do i get a copy my current profile will not let me download a copy?
Well... you can either ask your vendor who you purchased the 1532 from to get you that code, or you can try to open a TAC case since this is a new AP and see if they can publish that code for you.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
I loaded the new firmware into the 2504, the 1532 picked up a IP address & time from the 2504, but the 1532 still does not associate with the controler (does not show up under the wireless tab)?
we have 4 x 2504's do they all need to be upgraded to 7.6? I have only upgraded the controller with the lowest IP as this is the one all new AP's associate with first?
It looks like the 1532 is continualy re-booting every few minutes!
This is an part of the 1532 log
*Jan 22 23:07:12.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.204.101.12 peer_port: 5246
*Jan 22 23:07:13.443: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: xxxxxx peer_port: 5246
*Jan 22 23:07:13.443: %CAPWAP-5-SENDJOIN: sending Join Request to xxxxx
*Jan 22 23:07:13.447: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jan 22 23:07:13.447: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Jan 22 23:07:13.447: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jan 22 23:07:13.447: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from xxxx
*Jan 22 23:07:18.443: %CAPWAP-5-SENDJOIN: sending Join Request to xxx
*Jan 22 23:08:17.031: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Jan 22 23:08:17.079: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jan 22 23:08:17.079: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'xxxxx'running version 7.3.101.0 is rejected.
*Jan 22 23:08:17.079: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Jan 22 23:08:17.079: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Jan 22 23:08:17.079: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
thanks for your help.
Hall of Fame Super Gold
Can you please post the following output:
1.  WLC:  sh sysinfo;
2.  AP:  sh version
The most common culprit is the AP you purchased may have the INCORRECT regulatory domain.  For example, the AP will be installed in the US so the Regulatory Domain should be "-A" but you got an AP destined for, say, Germany which has a Regulatory Domain of "-E".
The AP was purchased in New Zealand for use in New Zealand
AP
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 78:DA:6E:59:A6:74
Part Number                          : 74-11942-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC17413ES0
Top Assembly Part Number             : 000-00000-00
Top Assembly Serial Number           : FGL1749U002
Top Revision Number                  : 23
Product/Model Number                 : AIR-CAP1532I-Z-K9
2504
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.100.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... NZIVC-2504-OPS
System Location.................................. NZAS, Ops Server Rm
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.204.101.12
Last Reset....................................... Software reset
System Up Time................................... 0 days 1 hrs 42 mins 55 secs
System Timezone Location......................... (GMT+12:00) Auckland (New Zeal
and)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... NZ  - New Zealand
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +25 C
External Temperature............................. +30 C
Fan Status....................................... 4800 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 7
Number of Active Clients......................... 5
Burned-in MAC Address............................ D4:8C:B5:C2:A9:E0
Maximum number of APs supported.................. 50
Please post the output to the AP command of "sh version".
I'm in Australia and we have purchased APs with the wrong regulatory domain.  You can purchase, in NZ, an AP with the wrong Regulatory Domain.  It will depend on your reseller to flag this.
John,
The WLC that this AP is connecting to isn't in v7.6. Look at the log:
The AP is rejecting the image. You need to upgrade the WLC. I would upgrade all of them if this AP might join any of them.
-Scott
Did you add the MAC address of the 1532 to the Mac filter of the WLC?
-Scott
No, we have never had too in the past, 3602 & 1242 just pick up an IP address & the image from the 2504 automaticly.
We have 4 x 2504 controllers, this morning I upgraded the firmware on the one with the lowest IP (this is the one all AP's start off associating with).
The show sysinfo from the 2504 shows it running 7.6.100.0
Some of what you are seeing there is the 1542 “giving up on the 2504 running 7.6 & then moving on to the other 2504’s that are still running the old firmware.
If you want I can e-mail you the full AP error log
from the AP
sh ver
Cisco IOS Software, C1530 Software (ap1g3-K9W8-M), Version 15.2(4)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 06-Nov-13 02:30 by prod_rel_team
ROM: Bootstrap program is C1530 boot loader
BOOTLDR: C1530 Boot Loader (ap1g3-BOOT-M), Version 15.2 [wnbubld 101]
AP78da.6e59.a674 uptime is 4 minutes
System image file is "flash:/ap1g3-k9w8-mx.152-4.JB/ap1g3-k9w8-mx.152-4.JB"
Last reload reason: Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1532I-Z-K9 (MIPS74k) processor (revision 23) with 204800K/57344K bytes of memory.
Processor board ID FGL1749U002
MIPS74k CPU at 700Mhz, revision number 0x0000
Last reset from power-on
LWAPP image version 7.6.1.118
2 Gigabit Ethernet interfaces
2 802.11 Radios
Configuration register is 0xF
Hmmmm ... That's odd.
Go here:  http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5861/product_data_sheet0900aecd80537b6a_ps10981_Products_Data_Sheet.html
Go to Table 3.  Look at the AP1532 column and match with NZ.  There is no "X" to mark the spot.  Wierd.
This model has only just been released in NZ
Okay.. We'll make sure the ap MAC address is in the Mac filter list.
-Scott
not sure what is ment hear?
John,
-Scott
Thank you, the AP has now associated with the controller, will I need to put the mac address in each controller?
Yes you will. This is a requirement for mesh AP's.
-Scott
2575
