1552e question
Dear All,
Can i use 1552e controller with 2504 wireless controller? and if  cisco has any design with this type of AP, please assist me, thank you
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
VIP Purple
1552e question
Yes you can use this AP wth 2504 Controller.
1552AP needs minimum software release 7.0.116.0
what kind of design you want ???, you need to connect this AP to WLC.
1552e question
VIP Purple
1552e question
1552e question
I thought i can use them as mesh network
VIP Purple
Re: 1552e question
Yes Its a mesh AP, and you can use this as Mesh.
First try to connect it to WLC.
dont forget to rate helpful posts
1552e question
Re: 1552e question
Hi Kamran,
Sharing the link for :
Cisco Wireless Mesh Access Points, Design and Deployment Guide:
http://www.cisco.com/en/US/docs/wireless/technology/mesh/7.0/design/guide/MeshAP_70.html
The AP can be used as MESH with RAP and MAP setup. We need to put the Ethernet mac of both the APs in the Mac filter list of the WLC and then they would join with the AP mode as Bridge. Once the AP joins the WLC in bridge mode then you can configure the sub mode that is RAP(Root Access Point) ot MAP(MESH Access Point).
Thanks and regards,
Manas Pratap Singh
185
