Community Member
1600 series Access Point. Simultaneous dual-band? Multi-SSID?
Hi everyone,
Researching the 1600 series access point and on this link:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps12555/data_sheet_c78-715702.html
I can't find the answers to:
  1. Are thesse AP's simultaneous dual-band? They work on both 2.4 and 5Ghz at the same time or I must select?
  2. Is it multi-SSID? Can I do SSID to tagged vlan traffic? If so how many?
Thanks very much
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
If it is a 1602, then yes it is 2.4GHz and 5GHz capable, if it is a 1601, then it is only 2.4GHz capable.
Yes, you can have mulitple SSID, up to 16, but you really want to keep the number of SSID to a minimum 2-3 max IMO.  The AP does allow you to call out a VLAN in your SSID config and map that SSID to a L2 VLAN.
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_7_JA/configuration/guide/s37vlan.html
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Hall of Fame Super Silver
Re: 1600 series Access Point. Simultaneous dual-band? Multi-SSID
> Yes the are
> the client device will decide it it will connect in the 2.4ghz or 5ghz
Is it multi-SSID?
> yes they support multiple SSIDs
> yes you can
If so how many?
> typically up to 16 SSID but best practice is to use no more than 4
-Scott
HTH,
Steve
> Yes the are
Is it multi-SSID?
> yes you can
If so how many?
-Scott
Community Member
Thanks very much for your time and experience
684
