Community Member
1602AP'interface Dot11Radio1 status reset down
SHO VER
Cisco IOS Software, C1600 Software (AP1G2-K9W8-M), Version 15.3(3)JN, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 26-Jun-14 02:41 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
1602 uptime is 3 days, 19 hours, 52 minutes
System image file is "flash:/ap1g2-k9w8-mx.153-3.JN/ap1g2-k9w8-xx.153-3.JN"
Last reload reason:
cisco AIR-CAP1602I-C-K9 (PowerPC) processor (revision B0) with 187382K/74672K bytes of memory.
Processor board ID xxx
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 10.2.102.0
1 Gigabit Ethernet interface
2 802.11 Radios
1602#SHO IP INT BRI
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       172.16.233.200  YES DHCP   up                    up
Dot11Radio0                unassigned      NO  unset  up                    up
Dot11Radio1                unassigned      NO  unset  reset                 down
1602#SHO LOG
*Sep  8 17:18:00.545: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Sep  8 17:18:00.577: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Sep  8 17:18:00.585: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to resetPCI reset port 1
*Sep  8 17:18:01.893: soap_pci_reconfig_radio: radio id 1
*Sep  8 17:18:20.021: Cmd Timeout After 12s
*Sep  8 17:18:20.021: mvl_handle_timeout called cmdtype=[0x9]
*Sep  8 17:18:21.625: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Sep  8 17:18:21.657: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Sep  8 17:18:21.665: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to resetPCI reset port 1
*Sep  8 17:18:22.973: soap_pci_reconfig_radio: radio id 1
*Sep  8 17:18:41.101: Cmd Timeout After 12s
Everyone's tags (1)
Hall of Fame Super Blue
Post the following command
Post the following command outputs:
  1. WLC:  sh sysinfo;
  2. AP:  sh inventory
Community Member
i have many 1602 AP connect
i have many 1602 AP connect to poe switch, only this 1602 ap with this issus
WLC 5760:
AIR-CT5760#sho  ver
Cisco IOS Software, IOS-XE Software, 5700 Series Wireless LAN Controller Softwar
e (CT5760-IPSERVICESK9-M), Version 03.06.00E RELEASE SOFTWARE (fc3)
Compiled Fri 27-Jun-14 01:01 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CT5760 Boot Loader (CT5760-HBOOT-M) Version 1.0, RELEASE SOFTWARE (P)
AIR-CT5760 uptime is 9 weeks, 5 days, 1 hour, 41 minutes
Uptime for this control processor is 9 weeks, 5 days, 1 hour, 43 minutes
System returned to ROM by reload at 11:20:13 UTC Wed Apr 9 2014
System restarted at 11:20:07 beijing Fri Jul 4 2014
System image file is "flash:packages.conf"
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Ipservices
License Type: Permanent
Next reload license Level: Ipservices
cisco AIR-CT5760 (i686) processor with 10485760K bytes of physical memory.
Processor board ID XXX
11 Virtual Ethernet interfaces
6 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
255000K bytes of Crash Files at crashinfo:.
3612840K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of  at webui:.
Base Ethernet MAC Address          : 1c:1d:86:25:68:00
Motherboard Assembly Number        : 73-14448-04
Motherboard Serial Number          : XXX
Model Revision Number              : A0
Model Number                       : AIR-CT5760
System Serial Number               : XXX
Switch Ports Model              SW Version        SW Image              Mode
*    1 6     AIR-CT5760         03.06.00E         ct5760-ipservicesk9   INSTALL
Configuration register is 0x201 (will be 0x102 at next reload)
AIR-CT5760#
And what country or
And what country or regulatory domain is the WLC configured for?
Community Member
i have lots of 1602 ap, only
i have lots of 1602 ap, only this ap with interface radio 1 reset down
country is cn
On the WLC, what is the
On the WLC, what is the output to the command "sh inventory"?
390
