Community Member
1852e AP Unable to join 2504 controller
I am experiencing an issue, 1852e AP Unable to join 2504 controller.
Following are the error I am receiving
Password: [*02/20/2017 11:10:03.4670] Selected MWAR 'Cisco-WLC' 10.23.2.100 (index 0).
[*02/20/2017 11:10:03.4670] Ap mgr count=1
[*02/20/2017 11:10:03.4670] Go join a capwap controller.
[*02/20/2017 11:10:03.4670] Choosing AP Mgr with index 0, IP = 10.23.2.100, load = 8..
[*02/20/2017 11:10:03.4670] Synchronizing time with AC time: 1487588994
[*02/20/2017 11:09:54.0000] CAPWAP State: DTLS Setup.
[*02/20/2017 11:09:54.1999] Bad certificate alert received from peer.
[*02/20/2017 11:09:54.1999] Ignoring callback message Close alert received..
[*02/20/2017 11:09:54.1999] DTLS: Received packet caused DTLS to close connection
[*02/20/2017 11:09:54.1999] Lost connection to the controller, going to restart CAPWAP...
[*02/20/2017 11:09:54.2099] Capwap restart.
[*02/20/2017 11:09:54.2099] CAPWAP State: DTLS Teardown.
[*02/20/2017 11:09:54.2199] [DP] Deleting capwap datapath
[*02/20/2017 11:09:54.2199] CAPWAP data tunnel delete from forwarding succeeded
Below are the device and firmware details.
Cisco Controller 2504 Firmware  version - 7.6.130.0
Cisco Access Point - 1852E
>show version from access point
AP80E8.6FD2.5F58#show version
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
Cisco AP Software, (ap1g4), [cheetah-build:/local/build/JENKINS/workspace/Nightly-Cheetah-corsica-c8_2_throttle-cco]
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri Dec 11 19:14:51 PST 2015
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version 21
AP80E8.6FD2.5F58 uptime is 0 days, 0 hours, 30 minutes
Last reload time : Thu Jun 30 00:15:01 UTC 2016
Last reload reason : unknown
cisco AIR-AP1852E-E-K9 ARMv7 Processor rev 0 (v7l) with 997136/779728K bytes of memory.
Processor board ID KWC1925000A
AP Running Image : 8.2.100.0
Primary Boot Image : 8.2.100.0
Backup Boot Image : 0.0.0.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : 0a4f55efe8a32b394e3881a2a53a5db0
NSS FW version : NSS.AK.1.0.c4-00026-E_custC-1.24160.1.29595.1
Base ethernet MAC Address : 80:E8:6F:D2:5F:58
Part Number : 0-0000-00
PCA Assembly Number : 074-13150-01
PCA Revision Number : 01
PCB Serial Number : KWC1925000A
Top Assembly Part Number : 000-00000-00
Top Assembly Serial Number : KWC1925000A
Top Revision Number : A0
Product/Model Number : AIR-AP1852E-E-K9
Please help.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Update the firmware of the controller.  1852 requires the controller to be running, a minimum of, 8.1.111.0 (and later).
I strongly recommend loading 8.2.141.0 if there are no legacy APs around.
And don't forget to read the Release Notes.
Community Member
Hi Leo,
Hi Leo,
I'm Looking for outdoor access point , which is supported by cisco 2504 wireless controller .
Can you suggest some .
Hall of Fame Super Silver
Access Point support no
Access Point support no matter if they are indoor or outdoor is code dependent. You need to choose any of the outdoor AP's and then look at the matrix to determine what controller code you need on your 2504.
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
-Scott
-Scott
Community Member
Re: Cisco Controller 2504
Dear All,
I have deployed WLC 5508 with version 8.2.161.0 and trying to join AIR-AP1832I-C-K9 .
But , It i showing below message .Please help to find out actual reason on this .
[*10/27/2017 10:35:19.3992] Re-Tx Count=12, Max Re-Tx Value=10, NumofPendingMsgs=1
[*10/27/2017 10:35:22.2484] Re-Tx Count=13, Max Re-Tx Value=10, NumofPendingMsgs=1
[*10/27/2017 10:35:25.1075] Re-Tx Count=14, Max Re-Tx Value=10, NumofPendingMsgs=1
[*10/27/2017 10:35:27.9566] Re-Tx Count=15, Max Re-Tx Value=10, NumofPendingMsgs=1
[*10/27/2017 10:35:30.8157] Re-Tx Count=16, Max Re-Tx Value=10, NumofPendingMsgs=1
[*10/27/2017 10:35:30.8157] Max retransmission count exceeded, going back to DISCOVER mode.
[*10/27/2017 10:35:30.8157] GOING BACK TO DISCOVER MODE
[*10/27/2017 10:35:30.8257] CAPWAP State: DTLS Teardown
[*10/27/2017 10:35:35.5542] CAPWAP State: Discovery
[*10/27/2017 10:35:35.5642] Discovery Request sent to 10.10.20.15, discovery type STATIC_CONFIG(1)
[*10/27/2017 10:35:40.5626] Discovery Request sent to 10.10.20.15, discovery type STATIC_CONFIG(1)
[*10/27/2017 10:35:40.5826] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*10/27/2017 10:35:40.5826] Discovery Response from 10.10.20.15
[*10/27/2017 10:35:45.0000] Discovery Response from 10.10.20.15
[*10/27/2017 10:35:50.0000] Discovery Response from 10.10.20.15
[*10/27/2017 10:35:45.0000] CAPWAP State: DTLS Setup
[*10/27/2017 10:35:45.1499] CAPWAP State: Join
[*10/27/2017 10:35:45.1499] Sending Join request to 10.10.20.15 through port 5264
[*10/27/2017 10:35:45.1499] Join Response from 10.10.20.15
[*10/27/2017 10:35:45.2499] CAPWAP State: Image Data
[*10/27/2017 10:35:45.2499] CAPWAP State: Configure
[*10/27/2017 10:35:45.3099] DTLS: packet too old or a replay distance=0, this_seq_num=1, last_seq_num=1
[*10/27/2017 10:36:04.1240] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Configure(8).
show version :
cisco AIR-AP1832I-C-K9 ARMv7 Processor rev 0 (v7l) with 966404/775148K bytes of memory.
Processor board ID KWC20490ANS
AP Running Image     : 8.2.161.0
Primary Boot Image   : 8.2.161.0
Backup Boot Image    : 8.2.141.0
2 802.11 Radios
Radio FW version : fcd2bcd29e5368a9b783f2cc6747e903
NSS FW version : NSS.AK.1.0.c10-00017-E_custC-1.67978.1
Base ethernet MAC Address            : 00:38:DF:1E:0C:D0
PCA Assembly Number                  : 074-104313-02
PCB Serial Number                    : KWC20490ANS
Top Assembly Serial Number           : KWC20490ANS
Product/Model Number                 : AIR-AP1832I-C-K9
It would be highly appreciated if your reply as I facing it for long time and i need to solve the problem .
With regards
Erfan
Community Member
Please look into the
Please look into the following link for troubleshooting some scenarios:
https://supportforums.cisco.com/document/69341/ap-fails-join-controller-lap-fails-join-wireless-lan-controller-wlc
The following link will show you compability of IOS releases with AP:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-147162
1404
