1941W configuration help needed
Our Deployment Scenario:-
1941W Gigabit Ethernet 0/0 is connected to the PPOE connection of the ISP.
Gigabit Ethernet 0/1 is connected to the wired LAN
I have created 2 wireless radio Cisco_Kamran_BGN which is operating at 2.4 Ghz Devices and Cisco_Kamran_A which is operating at 5Ghz Devices.
I have created 2 VLans for the Wireless.
Vlan 10 for Cisco_Kamran_A        192.168.10.x
Vlan 11 for Cisco _Kamran_BGN   192.168.11.X
The problem is the Wireless users are not getting the IP address from the respective DHCP server which has been configured on the Router.
Can please any from the community help me and show me where I am missing the configuration.
Please find my router  & ap configuration below.
Router Configuration
Router#
sh run
Building configuration...
Current configuration : 3022 bytes
! No configuration change since last restart
version 15.1
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$TdQt$npYeaf/W0kRElcfMggzJ31
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 192.168.11.1 192.168.11.10
ip dhcp pool DHCP
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 195.229.241.222 213.42.20.20
ip dhcp pool Cisco_Kamran_A
network 192.168.11.0 255.255.255.0
default-router 192.168.11.1
ip dhcp pool Cisco_Kamran_BGN
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 195.225.241.222 213.42.20.20
license udi pid CISCO1941W-E/K9 sn FCZ1553C1VK
hw-module ism 0
redundancy
bridge irb
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered GigabitEthernet0/0
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip access-group DSL_ACCESSLIST in
ip nat inside
interface Vlan11
ip address 192.168.11.1 255.255.255.0
ip nat inside
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication pap callin
ppp pap sent-username xxxxxx password 0 xxxxxx
ppp ipcp route default
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list DSL_ACCESSLIST interface Dialer1 overload
ip access-list extended DSL_ACCESSLIST
permit ip 192.168.0.0 0.0.255.255 any
control-plane
line con 0
password xxxxxx
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
line vty 0 4
password xxxxxx
login
transport input all
scheduler allocate 20000 1000
end
Router#
Router#
Router#
Access Point Configuration
ap#
ap#
ap#
sh run
Current configuration : 2603 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$JxdQ$a2/00bWJuhUKP9QLC94YD/
no aaa new-model
dot11 syslog
dot11 ssid Cisco_Kamran_A
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 1045081417161C5A555C7A7B
dot11 ssid Cisco_Kamran_BGN
   authentication open
   guest-mode
   wpa-psk ascii 7 020D05561907017015165949
username Cisco password 7 14341B180F0B
bridge irb
interface Dot11Radio0
description 802.11bgn radio
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
broadcast-key change 3600
antenna gain 0
station-role root
bridge-group 11
bridge-group 11 subscriber-loop-control
bridge-group 11 block-unknown-source
no bridge-group 11 source-learning
no bridge-group 11 unicast-flooding
bridge-group 11 spanning-disabled
interface Dot11Radio1
description 802.11a radio
no ip address
no ip route-cache
ssid Cisco_Kamran_A
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 10 spanning-disabled
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
bridge-group 1 spanning-disabled
interface GigabitEthernet0.10
description 802.11a bridge
encapsulation dot1Q 10
no ip route-cache
bridge-group 10
interface GigabitEthernet0.11
description 802.11bgn bridge
encapsulation dot1Q 11
no ip route-cache
bridge-group 11
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
ap#
ap#
ap#
Re: 1941W configuration help needed
You need to add the .10 and .11 sub interfaces for the radios as well. And call the VLAN under the SSID config.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Hi Stephen,
thanks for the reply
Please if you can provide me with the commands which i need to execute. Also other thing i noticed is that my wireless clients are not getting the IP Address from the dhcp which is configured on the router. If i assing them manual IP address it works fine. But i think i have done something wrong, if i connect to the wirless network named Cisco_Kamran_A and i manually give them the ip address 192.168.11.x it does not work. I need to give them the ip address of 192.168.10.x and it works. Please if you can correct me where i have done a mistake.
conf t
no ssid Cisco_Kamran_BGN
no encryption mode ciphers aes-ccm
exit
no ssid Cisco_Kamran_A
exit
vlan 10
vlan 11
exit
encryption vlan 11 mode ciphers aes
exit
interface dot11radio0.1
encapsulation dot1q 1 native
bridge-group 1
interface dot11radio 0.11
encapsulation dot1q 11
bridge-group 11
exit
encryption vlan 10 mode ciphers aes-ccm
ssid Cisco_Kamran_A
interface dot11radio1.1
bridge-group 1
interface dot11radio1.10
encapuslation dot1q 10
bridge-group 10
end
wr
Hi Stepehen,
Did the configuration as per your advice  but i am getting the below mentioned error which i have highlighted it in red. Please advice what needs to be done.
Home
created by Stephen Rodriguez in Getting     Started with Wireless - View the full discussion
conf t
exit
exit
vlan 10
vlan 11
exit
exit
bridge-group 1
bridge-group 11
Configuration of     subinterfaces and main interface
within the same bridge     group is not permitted
exit
ssid     Cisco_Kamran_A
bridge-group 1
bridge-group 10
end
wr
Reply to this message by going to Home
Start a new discussion in Getting Started with Wireless at Home
Ok, go into the Dot11Radio 0 and do a no bridge-group 11, and Dot11Radio 1 and no bridge-group 11.
then
bridge-group 10
  and
bridge-group 11
Steve
Hi Stepehen,
still no luck.. Please find the configuration of the ap below as per what you have instructed. Untill now my wireless clients are not able to get the ip from the DHCP.
ap#
ap#
ap#sh run
Current configuration : 3215 bytes
version 12.4
no service pad
hostname ap
no aaa new-model
dot11 syslog
   vlan 10
   authentication open
   guest-mode
   vlan 11
   authentication open
   guest-mode
bridge irb
no ip address
no ip route-cache
encryption vlan 11 mode ciphers aes-ccm
antenna gain 0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 unicast-flooding
interface Dot11Radio0.11
no ip route-cache
bridge-group 11
no ip address
no ip route-cache
ssid Cisco_Kamran_A
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.10
no ip route-cache
bridge-group 10
no ip address
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 10
no ip route-cache
bridge-group 11
interface BVI1
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
end
ap#
ap#
ap#
564
