2.4 Ghz Channels
Prasan Venky
Level 3
Level 3
Hi All,
In higher density ap environment, 2.4 ghz with three non-overlapping channels will interference. how to avoid that?
5 Replies 5
Stephen Rodriguez
Currently you need to manually go in and either disable or turn some of the 2.4GHz radios into monitor mode.
Once you do that, remember to go back and resurvey to make sure that you still have the coverage requirements you need.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
d.mikheyenko
Saurav Lodh
Level 7
Level 7
3 channel design is itself an optimized way of using frequencies wisely, as it gives you non overlapping group of frequencies. However , in highly condensed environment, channel resuse sometimes creates issues. signal of one client becomes noise for other. Therefore, you need to manual select the radios. Please refer to cisco doc for more info
http://www.cisco.com/en/US/docs/wireless/technology/channel/deployment/guide/Channel.html
Rate the helpful posts!
Regards!
Scott Fella
Bottom line is to tweak your power and data rates. I have deployed many schools with one AP or more in each classroom and never turned off an 2.4 ghz radios. That's my opinion:)
-Scott
