2500 WLC & 1262 AP converted to LAP will not connect
We are having a problem whereby, three new access points will not connect to the Wireless Controller.
We flashed the devices to LAP operation using the recovery images on the Cisco website, but upon rebooting we get the error message.
*Oct 10 16:31:38.004: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default config
*Oct 10 16:31:48.014: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct 10 16:31:47.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.xx.xx peer_port: 5246
*Oct 10 16:31:47.427: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.xx.xx peer_port: 5246
*Oct 10 16:31:47.427: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.xx.xx
*Oct 10 16:31:47.430: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Oct 10 16:31:47.430: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Oct 10 16:31:47.430: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Oct 10 16:31:47.430: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 192.168.xx.xx
*Oct 10 16:31:52.429: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.xx.xx
And the lights now cycle Blur/Green/Red/Off
We have two other access points, same model, on another site connected to the controller and they are working without any problems.
Googling we have been unable to find any answer to the problem.
  • Getting Started with Wireless
Everyone's tags (5)
VIP Purple
Try the below & see whether it makes any difference. Take the console output & post it again if it is not registering still
LAP#clear capwap private-config
LAP#reload
System configuration has been modified. Save? [yes/no]: yes
Proceed with reload? [confirm]
Writing out the event log to flash:/event.log ...
Rasika
**** Pls rate all useful responses ****
Seems there is a difference in the country code between AP and the WLC..  could you please check that and configure the right regulatory  domain/country code on WLC for that AP?
probably 'debug capwap errors enable' and 'debug dtls info enable' will give you more inputs
Hall of Fame Super Gold
Post the following output:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh ip interface brief; and
5.  AP:  sh inventory
sh version
Cisco IOS Software, C1260 Software (AP3G1-RCVK9W8-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 10-Dec-12 23:48 by prod_rel_team
ROM: Bootstrap program is C1260 boot loader
BOOTLDR: C1260 Boot Loader (AP3G1-BOOT-M), Version 12.4 [mpleso-ap_jmr3_esc_0514 125]
APf872.ea76.d52b uptime is 4 minutes
System returned to ROM by reload
System image file is "flash:/ap3g1-rcvk9w8-mx/ap3g1-rcvk9w8-xx"
Last reload reason:
--More--
*Oct 11 08:31:34.423: %CAPWAP-5-SENDJOIN: sending Join Request to 192.agree to comply with applicable laws and regulations. If you are unable
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1262N-E-K9     (PowerPC460exr) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1725W0MP
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from reload
LWAPP image version 7.4.1.37
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F8:72:EA:76:D5:2B
Part Number                          : 73-12175-06
PCA Assembly Number                  : 800-32268-06
PCA Revision Number                  : B0
PCB Serial Number                    : FOC172323WX
Top Assembly Part Number             : 800-33866-02
Top Assembly Serial Number           : FCZ1725W0MP
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1262N-E-K9
Configuration register is 0xF
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       192.168.16.125  YES DHCP   up                    up
GigabitEthernet0           unassigned      NO  unset  up                    up
GigabitEthernet0.1         unassigned      YES unset  up                    up
sh inventory
-- no output --
show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.5.102.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... SynergyWIFIController
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.xx.xx
Last Reset....................................... Software reset
System Up Time................................... 2 days 15 hrs 36 mins 46 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... GB  - United Kingdom
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +25 C
External Temperature............................. +30 C
Fan Status....................................... 3800 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 1
Burned-in MAC Address............................ AC:
show time
Time............................................. Fri Oct 11 08:51:26 2013
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
    NTP Polling Interval.........................     86400
     Index     NTP Key Index                  NTP Server                  NTP Msg Auth Status
Can you run 'debug capwap events enable' at the WLC and dump its messages here?
Thanky you.
Thanks for the output.
The only thing wrong I can see is your WLC is not configured for network time (NTP).  If the time/date of your WLC is not set right, the AP will not join.  This is because the AP has a certificate and it uses the time/date of the WLC.
Next, if you console into the AP, can the AP ping the Management IP Address of the WLC?  If it can, then issue this enable command "config capwap ap controller ip address ".  If this command works, this means your DHCP may not have the correct Option 43 and/or your DNS may have the wrong configuratoin for the CISCO-CAPWAP-CONTROLLER.
Re: 2500 WLC & 1262 AP converted to LAP will not connect
Thanks everybody for the help so far, still not working yet though
Leo - I have added NTP on the wireless controller but this hasn't had any effect. I tried manually connecting to the WLC from the AP but same problem. I have two other AP in another site that connect to the AP just fine, so I am assuming DHCP and DNS are fine?
Vlad - Please see the log below.
*spamApTask5: Oct 14 08:17:27.174: f8:72:ea:76:d5:20 Discovery Request from 192.168.xx.xx:27987
*spamApTask5: Oct 14 08:17:27.174: f8:72:ea:76:d5:20 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 5, joined Aps =2
*spamApTask5: Oct 14 08:17:27.174: f8:72:ea:76:d5:20 Discovery Response sent to 192.168.xx.xx port 27987
*spamApTask5: Oct 14 08:17:27.174: f8:72:ea:76:d5:20 Discovery Response sent to 192.168.xx.xx:27987
*spamApTask5: Oct 14 08:17:27.175: f8:72:ea:76:d5:20 Discovery Request from 192.168.xx.xx:27987
*spamApTask5: Oct 14 08:17:27.175: f8:72:ea:76:d5:20 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 5, joined Aps =2
*spamApTask5: Oct 14 08:17:27.176: f8:72:ea:76:d5:20 Discovery Response sent to 192.168.xx.xx port 27987
*spamApTask5: Oct 14 08:17:27.176: f8:72:ea:76:d5:20 Discovery Response sent to 192.168.xx.xx:27987
*spamApTask5: Oct 14 08:17:37.109: f8:72:ea:76:d5:20 DTLS connection not found, creating new connection for 192:168:xx:xx (27987) 192:168:yy:yy (5246)
*spamApTask5: Oct 14 08:17:37.529: acDtlsPlumbControlPlaneKeys: lrad:192.168.xx.xx(27987) mwar:192.168.yy.yy(5246)
*spamApTask5: Oct 14 08:17:37.530: f8:72:ea:76:d5:20 Allocated index from main list, Index: 27
*spamApTask5: Oct 14 08:17:37.530: f8:72:ea:76:d5:20 Using CipherSuite AES128-SHA
*spamApTask5: Oct 14 08:17:37.530: f8:72:ea:76:d5:20 DTLS keys for Control Plane are plumbed successfully for AP 192.168.xx.xx. Index 28
*spamApTask4: Oct 14 08:17:37.531: f8:72:ea:76:d5:20 DTLS Session established server (192.168.yy.yy:5246), client (192.168.xx.xx:27987)
*spamApTask4: Oct 14 08:17:37.531: f8:72:ea:76:d5:20 Starting wait join timer for AP: 192.168.xx.xx:27987
*spamApTask5: Oct 14 08:17:37.533: f8:72:ea:76:d5:20 Join Request from 192.168.xx.xx:27987
*spamApTask5: Oct 14 08:17:37.533: f8:72:ea:76:d5:20 Deleting AP entry 192.168.xx.xx:27987 from temporary database.
*spamApTask5: Oct 14 08:17:37.534: f8:72:ea:76:d5:20 In AAA state 'Idle' for AP f8:72:ea:76:d5:20
*spamApTask5: Oct 14 08:17:37.535: f8:72:ea:76:d5:20 Join Request failed!
*spamApTask0: Oct 14 08:17:37.539: f8:72:ea:76:d5:20 Finding DTLS connection to delete for AP (192:168:xx:xx/27987)
*spamApTask0: Oct 14 08:17:37.540: f8:72:ea:76:d5:20 Disconnecting DTLS Capwap-Ctrl session 0x17729778 for AP (192:168:xx:xx/27987)
*spamApTask0: Oct 14 08:17:37.540: f8:72:ea:76:d5:20 CAPWAP State: Dtls tear down
*spamApTask0: Oct 14 08:17:37.540: acDtlsPlumbControlPlaneKeys: lrad:192.168.xx.xx(27987) mwar:192.168.yy.yy(5246)
*spamApTask0: Oct 14 08:17:37.540: f8:72:ea:76:d5:20 DTLS keys for Control Plane deleted successfully for AP 192.168.xx.xx
*spamApTask5: Oct 14 08:17:37.547: f8:72:ea:76:d5:20 DTLS connection closed event receivedserver (192.168.yy.yy/5246) client (192.168.xx.xx/27987)
*spamApTask5: Oct 14 08:17:37.547: f8:72:ea:76:d5:20 Entry exists for AP (192.168.xx.xx/27987)
*spamApTask5: Oct 14 08:17:37.548: f8:72:ea:76:d5:20 No AP entry exist in temporary database for 192.168.xx.xx:27987
*spamApTask6: Oct 14 08:18:36.757: f8:72:ea:76:d5:20 Discovery Request from 192.168.xx.xx:27988
*spamApTask6: Oct 14 08:18:36.757: f8:72:ea:76:d5:20 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 5, joined Aps =2
*spamApTask6: Oct 14 08:18:36.757: f8:72:ea:76:d5:20 Discovery Response sent to 192.168.xx.xx port 27988
*spamApTask6: Oct 14 08:18:36.757: f8:72:ea:76:d5:20 Discovery Response sent to 192.168.xx.xx:27988
*spamApTask6: Oct 14 08:18:36.758: f8:72:ea:76:d5:20 Discovery Request from 192.168.xx.xx:27988
*spamApTask6: Oct 14 08:18:36.758: f8:72:ea:76:d5:20 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 5, joined Aps =2
*spamApTask6: Oct 14 08:18:36.758: f8:72:ea:76:d5:20 Discovery Response sent to 192.168.xx.xx port 27988
*spamApTask6: Oct 14 08:18:36.758: f8:72:ea:76:d5:20 Discovery Response sent to 192.168.xx.xx:27988
*spamApTask6: Oct 14 08:18:36.759: f8:72:ea:76:d5:20 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 5, joined Aps =2
*spamApTask6: Oct 14 08:18:36.759: f8:72:ea:76:d5:20 Discovery Response sent to 192.168.xx.xx port 27988
*spamApTask6: Oct 14 08:18:36.759: f8:72:ea:76:d5:20 Discovery Response sent to 192.168.xx.xx:27988
*spamApTask0: Oct 14 08:18:36.759: f8:72:ea:76:d5:2b Received LWAPP DISCOVERY REQUEST to ac:f2:c5:a0:95:80 on port '1'
*spamApTask0: Oct 14 08:18:36.759: f8:72:ea:76:d5:2b Discarding discovery request in LWAPP from AP supporting CAPWAP
*spamApTask6: Oct 14 08:18:46.692: f8:72:ea:76:d5:20 DTLS connection not found, creating new connection for 192:168:xx:xx (27988) 192:168:yy:yy (5246)
*spamApTask6: Oct 14 08:18:47.113: acDtlsPlumbControlPlaneKeys: lrad:192.168.xx.xx(27988) mwar:192.168.yy.yy(5246)
*spamApTask6: Oct 14 08:18:47.114: f8:72:ea:76:d5:20 Allocated index from main list, Index: 28
*spamApTask6: Oct 14 08:18:47.114: f8:72:ea:76:d5:20 Using CipherSuite AES128-SHA
*spamApTask6: Oct 14 08:18:47.115: f8:72:ea:76:d5:20 DTLS keys for Control Plane are plumbed successfully for AP 192.168.xx.xx. Index 29
*spamApTask4: Oct 14 08:18:47.115: f8:72:ea:76:d5:20 DTLS Session established server (192.168.yy.yy:5246), client (192.168.xx.xx:27988)
*spamApTask4: Oct 14 08:18:47.115: f8:72:ea:76:d5:20 Starting wait join timer for AP: 192.168.xx.xx:27988
*spamApTask6: Oct 14 08:18:47.117: f8:72:ea:76:d5:20 Join Request from 192.168.xx.xx:27988
*spamApTask6: Oct 14 08:18:47.118: f8:72:ea:76:d5:20 Deleting AP entry 192.168.xx.xx:27988 from temporary database.
*spamApTask6: Oct 14 08:18:47.118: f8:72:ea:76:d5:20 In AAA state 'Idle' for AP f8:72:ea:76:d5:20
*spamApTask6: Oct 14 08:18:47.120: f8:72:ea:76:d5:20 Join Request failed!
*spamApTask0: Oct 14 08:18:47.123: f8:72:ea:76:d5:20 Finding DTLS connection to delete for AP (192:168:xx:xx/27988)
*spamApTask0: Oct 14 08:18:47.123: f8:72:ea:76:d5:20 Disconnecting DTLS Capwap-Ctrl session 0x177298f0 for AP (192:168:xx:xx/27988)
*spamApTask0: Oct 14 08:18:47.123: f8:72:ea:76:d5:20 CAPWAP State: Dtls tear down
*spamApTask0: Oct 14 08:18:47.123: acDtlsPlumbControlPlaneKeys: lrad:192.168.xx.xx(27988) mwar:192.168.yy.yy(5246)
*spamApTask0: Oct 14 08:18:47.123: f8:72:ea:76:d5:20 DTLS keys for Control Plane deleted successfully for AP 192.168.xx.xx
*spamApTask6: Oct 14 08:18:47.131: f8:72:ea:76:d5:20 DTLS connection closed event receivedserver (192.168.yy.yy/5246) client (192.168.xx.xx/27988)
*spamApTask6: Oct 14 08:18:47.131: f8:72:ea:76:d5:20 Entry exists for AP (192.168.xx.xx/27988)
*spamApTask6: Oct 14 08:18:47.132: f8:72:ea:76:d5:20 No AP entry exist in temporary database for 192.168.xx.xx:27988
VIP Purple
As requested earlier, post the complete AP console output after issue the following command. That should give if any error messages while booting the AP.
LAP#reload
Rasika
1349
