2504 controller
started configuring our 2504 controller, I connected 2504 port 1 to 3750 port, trunked with untagged management vlan 50, when I connect my pc to the switch on vlan 50 I can browse to the 2504 controller, when I try to browse to the controller from vlan 2 it doesn't connect. I do have eigrp running and the networks are defined to eigrp.
Are these Layer 3 VLANs or
Are these Layer 3 VLANs or SVI? If so, do you have ip routing enabled?
sh run | i ip routing
If it is a directly connected subnet it won't rely on EIGRP to route you to VLAN2.
Hey, If your question is
Hey,
If your question is there a limitation to access the WLC form only management VLAN PC the answer is no.
As long as you have allowed VLANs to communicate in your wired network you will be able to reach
Cheers,
Nour
53
