2504 Uplinked to 2 switches
Would someone be able to confirm that its possible to use 2 ports on the 2504 and connect each port to a separate switch for redundancy?
So i have 2 seperate switches and would like to connect port 1 on the WLC to switch 1 and port 2 on the WLC to switch 2.
Port 1 would be the primary port for management and all other interfaces and port 2 the secondary.
Code would be 7.4.110.0
Thanks in advance
1 ACCEPTED SOLUTION
VIP Purple
Yes, this is possible. Only when you createa LAG, you cannot connect two ports into two different switches.
Rasika
**** Pls rate all useful responses *****
1 REPLY
VIP Purple
Rasika
95
