2504 Wireless Controller|AIR-CAP1602I-x-K9
 I am trying to setup two SSID -one being the guest wireless (let's say 172.1.1.0/24) and the other one being the wireless for internal users (let's say 10.1.1.0/24).  The problem I am facing is re: the multiple interfaces and/or LAG on the 2504 controller
The current setup is ASA(DMZ interface 1 172.1.1.0/24) is connected to AP as a trunk
                                 ASA(Inside interface 2 10.1.1.0/24) is connected to netgear switch (L3 managed) as a trunk
                                 WLC is connected via port 1 and 2 to netgear switch as LAG
ASA inside has DHCP and all clients will get a valid DHCP lease 10.1.1.10-10.1.1.30
Because of the existing design, the management address of WLC and AP are 10.1.1.0/24 and 172.1.1.20/24 respectively .However, once I configure the LAG on the 2504 controller I am not able to manage my WLC anymore (being connected to the netgear switch directly with ip 10.1.1.11)
Any recomendation of the setup? This is the first time I am setting up a wireless cisco controller so any recommendation would be welcomed.
Should the AP and WLC be on the same subnet?If yes should they be on the "inside" or the "DMZ" interface or it doesn't really matter?
Pantelis
Everyone's tags (2)
VIP Purple
Check this link: http://www
Check this link:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/70937-guest-internal-wlan.html
According to the cisco
According to the cisco documentation, no LAG is used.Also the WLC and the AP are part of the same subnet? Is that best practises?
VIP Purple
Yes, AP and WLC in same
Yes, AP and WLC in same subnet is best practice to have.
Thanks Sandeep- I will
Thanks Sandeep- I will reconfigure the WLC and AP and post back. I assume the management port will go on port 1 and be the only ap-manager ?
VIP Purple
Yes,you don't to configure AP
Yes,
you don't to configure AP manager.
On the old WLC models like 2100, 2006,4400  had to configure the management interface for managing the WLC and the AP manager so that the APs could create the LWAPP or CAPWAP tunnel to the WLC.
On the new model of WLCs like the 2500,5508 the AP manager interface is not required, the management interface if it has the check for dynamic interface it will work at the same time as the AP manager interface.
I've connected port 1 of the
I've connected port 1 of the controller to the netgear as access port (that would take a 10.1.0.x address which will act as a management port as well). Port 2 of the controller would be connected directly to the DMZ port of the ASA in order to get a 172.1.1.x address and be used for GUest Wifi. For simplicity I will connect the AP to the same L2 as the Controller (10.1.1.x network) . However , If I try to create another interface for the internal clients for the same subnet I get a subnet configuration error (tried to add interface "internal clients" but becasue of the ip/subnet conflict the WLC reset them to 0.0.0.0 )
(Cisco Controller) >show interface summary
Number of Interfaces.......................... 4
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
guest                            2    20       172.1.1.10     Dynamic No     No
inside-clients                   1    10       0.0.0.0         Dynamic No     No   <-if I try to configure ip ,it conflicts with management interface
management                       1    untagged 10.1.1.16       Static  Yes    No
virtual                          N/A  N/A      172.50.50.50    Static  No     No
Am I right to assume that I can map the management interface to the SSID to act as the internal clients subnet even though traffic between controller and netgear is untagged? I've managed to set up the SSID (using the management interface thought ) and got internal IP from ASA DHCP
Pantelis
397
