Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
2504 WLC drops connection
Hi to all,
Please help me with my issue. Our company is the owner of Cisco 2504 WLC + 3 Cisco Aironet 1600 AIR-CAP1602I-E-K9 Access Points. One of them in Rogue Detection mode.
Sometimes all of my wireless clients disconnecting from WLANs and connectiong againg after 1-2 seconds. I check the logs and what I found:
*apfReceiveTask: Feb 11 17:59:00.817: #MM-3-APENTRY_DEL_FAILED: mm_aplist.c:725 Could not delete an AP from the AP list.
*apfReceiveTask: Feb 11 17:58:26.563: #MM-3-APENTRY_DEL_FAILED: mm_aplist.c:725 Could not delete an AP from the AP list.
*spamApTask6: Feb 11 17:58:11.253: #LOG-3-Q_IND: mm_aplist.c:725 Could not delete an AP from the AP list.
*apfReceiveTask: Feb 11 17:58:06.663: #MM-3-APENTRY_DEL_FAILED: mm_aplist.c:725 Could not delete an AP from the AP list.
*spamApTask7: Feb 11 17:58:06.655: #CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:6655 Did not receive heartbeat reply; AP: c0:7b:bc:6b:b4:50
*spamReceiveTask: Feb 11 17:57:31.236: #LOG-3-Q_IND: mm_aplist.c:725 Could not delete an AP from the AP list.
*apfReceiveTask: Feb 11 17:57:31.236: #MM-3-APENTRY_DEL_FAILED: mm_aplist.c:725 Could not delete an AP from the AP list.
*spamApTask7: Feb 11 17:57:31.226: #CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:6655 Did not receive heartbeat reply; AP: c0:7b:bc:f0:4d:40
*apfReceiveTask: Feb 11 17:56:36.594: #MM-3-APENTRY_DEL_FAILED: mm_aplist.c:725 Could not delete an AP from the AP list.
*apfReceiveTask: Feb 11 17:53:57.837: #MM-3-APENTRY_DEL_FAILED: mm_aplist.c:725 Could not delete an AP from the AP list.
Could you please assist me with this issue, Thanks in advance
Elbrus
Everyone's tags (5)
Hall of Fame Super Silver
Disable RLDP if you have that enabled.  Post your show wlan
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Re: 2504 WLC drops connection
Hi Scott,
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... XXXX Staff
Network Name (SSID).............................. XXXX
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 12
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 12 hours
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... CiscoWLC
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ 192.168.0.101 1812
   Accounting.................................... 192.168.0.101 1813
      Interim Update............................. Disabled
      Framed IPv6 Acct AVP ...................... Prefix
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Split Tunnel (Printers).......................... Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority  Policy Name
P.S.Rogue Location Discovery Protocol was disabled
The wlan looks fine.... if RLDP was disabled, then it might be something else.  I would try to isoloate the issue with certain devices and then also look at those devices.
Per this link:
http://www.cisco.com/en/US/docs/wireless/controller/message/guide/msgs7.html
Error Message    %MM-3-APENTRY_DEL_FAILED: Could not delete an AP from the AP list.
Explanation    Internal system error
Recommended Action    If this message recurs, copy the message exactly as it appears on the console  or in the system log. Research and attempt to resolve the issue using the tools and utilities provided  at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying  information. Search for resolved software issues using the Bug Toolkit at  http://tools.cisco.com/Support/BugToolKit/. If you still require assistance, open a case with the  Technical Assistance Center via the Internet at  http://tools.cisco.com/ServiceRequestTool/create/launch.do, or contact your Cisco technical  support representative and provide the representative with the information you have gathered.
Scott
-Scott
VIP Purple
Its a Internal system error.
You must raise a TAC case and try to solve with them.
Hope it helps.
Dont forget to rate helpful posts
Thanks guys!
742
