2504 WLC not seeing APs
I'm using a 2504 WLC with 1041 LWAP.  All works fine until everything is switched off for some hours.  On power up the APs eventually end up with a solid green light but when I'm on the monitor screen on the 2504 it doesn't show any APs connected to it.
If I default and start again, the APs will come up.  If I power off for only a few minutes they will come back up.  It's when everything is switched off for some hours that the APs won't come back up.  I've upgraded the s/w to 8.0.100.0.  The configuration seems to remain intact on the controller even after a long power off.
Any ideas?
Is the time on the WLC still
Is the time on the WLC still accurate after the "long" reboot? Do the access-points get powered off as well?
Please post the output for the following commands on the WLC while the access-point is trying to join:
  • debug capwap events enable
  • debug capwap error enable
  • debug disable-all (to turn of the debugs)
Also include all console information of a access-point while it is booting and trying to join the WLC.
Debug the Join process ,
Debug the Join process , refer " debug Capwap " from
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70lwap.html#wp1508179
49
