2504WLC with Aironet3702i Configuration issue
I'm brand new to wireless lan controllers, and I'm having an issue that I just can't quite figure out.  The AP is finding the WLC and doing what it's supposed to do, however, when a device connects to the 5GHZ band, there are issues.  The device is unable to connect to the web, has issues finding other devices on the network, and browsing just does not work.  I am able to ping public IP addresses when connected to the 5GHZ band, but can't pull up anything using Comcast's DNS.  When a device is using the 2.4GHZ band, there are no issues.  I've attached my configuration as a text file.
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Why would the issue only affect the 5GHZ radio and not the 2.4GHZ?
You still haven't responded as to the status to the wireless NIC drivers.  Are they updated?
Full strength, I'm about 9 feet away from it.  Continuous ping shows no issues, aside from varying response times.
This rules out wireless.
Can you please post the following:
1.  WLC:  sh sysinfo;
2.  AP:  sh version
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.100.0
Bootloader Version............................... 1.0.18
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_cb:6b:24
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.1.250
Last Reset....................................... Software reset
System Up Time................................... 0 days 1 hrs 28 mins 0 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +29 C
External Temperature............................. +32 C
Fan Status....................................... 4000 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 1
Number of Active Clients......................... 4
Burned-in MAC Address............................ 50:06:04:CB:6B:20
Maximum number of APs supported.................. 5
AP7cad.74ff.c37a>sh ver
Cisco IOS Software, C3700 Software (AP3G2-K9W8-M), Version 15.2(4)JB3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 18-Dec-13 22:30 by prod_rel_team
ROM: Bootstrap program is C3700 boot loader
BOOTLDR: C3700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB, RELEASE SOFTWARE (fc1)
AP7cad.74ff.c37a uptime is 1 hour, 21 minutes
System image file is "flash:/ap3g2-k9w8-mx.152-4.JB3/ap3g2-k9w8-xx.152-4.JB3"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3702I-A-K9 (PowerPC) processor (revision A0) with 204790K/57344K bytes of memory.
Processor board ID FTX174973EQ
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.6.100.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 7C:AD:74:FF:C3:7A
Part Number                          : 73-15243-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC174473R6
Top Assembly Part Number             : 068-05054-01
Top Assembly Serial Number           : FTX174973EQ
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP3702I-A-K9
Configuration register is 0xF
Re: 2504WLC with Aironet3702i Configuration issue
Ummmm ... This is the reason why.
On the WLC, enter this CLI command:  config 802.11a enable network
Sorry, I forgot to mention I temporarily disabled it.
Ok, post the output to the command "sh wlan ".
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... The Tardis
Network Name (SSID).............................. The Tardis
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 12 hours
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... Cisco_cb:6b:24
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream          Downstream
Average Data Rate................................   0                      0
--More-- or (q)uit
Average Realtime Data Rate.......................   0                      0
Burst Data Rate..................................   0                      0
Burst Realtime Data Rate.........................   0                      0
Per-Client Rate Limits........................... Upstream          Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
--More-- or (q)uit
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
      Framed IPv6 Acct AVP ...................... Prefix
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
--More-- or (q)uit
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
--More-- or (q)uit
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
   Eap-params.................................... Disabled
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Split Tunnel (Printers).......................... Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
--More-- or (q)uit
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority  Policy Name
1.  Use either TKIP or AES.  Don't enable both.
2.  Make sure your wireless client's wireless NIC driver is updated.  Go the the wireless NIC manufacturer's website for updated drivers (avoid going to the laptop's manufacturer's website)
Okay, I went back to using only AES, and I'm still having the same issue.  For instance, I can ping a public IP such as 8.8.8.8, but I cannot ping google.com .  When I go to ping my router (a 2901), it will time out for the first 6 or 7 tries, and then it starts pinging.
That sounds like a routing issue.
I presume the Default Gateway of the WLC Management port is the router or Comcast router?
Yes, the default gateway is the router.  Why would the issue only affect the 5GHZ radio and not the 2.4GHZ?
What is the signal strength of the wireless client when connected on the 5 Ghz radio?
What happens if you have a continuous ping from the wireless client to the default-gateway?
PING 192.168.1.1 (192.168.1.1): 56 data bytes
64 bytes from 192.168.1.1: icmp_seq=0 ttl=255 time=1.078 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=255 time=102.444 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=255 time=41.341 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=255 time=85.213 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=255 time=23.974 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=255 time=67.876 ms
64 bytes from 192.168.1.1: icmp_seq=6 ttl=255 time=2.036 ms
64 bytes from 192.168.1.1: icmp_seq=7 ttl=255 time=50.996 ms
64 bytes from 192.168.1.1: icmp_seq=8 ttl=255 time=94.706 ms
Sorry, yes, all the NIC drivers are updated.  I wasn't having an issue when I was running the AP in autonomous mode.  I have a backup AP (an aironet 1042i) running in autonomous mode with no issues.
I am a massive idiot.  I had the switch port the WLC is connected to configured on a VLAN trunked with another port.  I removed the settings in question and everything's fine.
On your router, please post the output to the command "sh interface ".
It was a configuration issue on the port on my Catalyst switch that was causing the issue.  You were totally right, it had nothing to do with wireless.
Thanks for the confirmation, Joshua.
618
