2600 IOS conversion issues
For the past couple hours I've been trying to convert an AIR-CAP2602I-A-K9 and have hit a brick wall due to some networking issues with the MODE button method.
For some reason when the mode button is held down, the AP's IP interface is non responsive.  It self-assigns 10.0.0.1 and I can't ping it from my laptop (10.0.0.4).  However, when I run a DHCP server on my laptop and let the AP boot with it's CAPWAP image, the two can talk to each other.
I've tried the following method to download IOS code to the AP but keep getting interrupted by the controller discovery process.
#archive download-sw /force-reload /overwrite tftp://10.0.0.4/ap3g2-k9w7-tar.tar
I watch files download and extract but can't seem to get it completed before the AP times out discovering a controller and reset's its ip.
*Mar  1 00:22:02.431: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
I'm really struggling here and don't have a controller.  If I did I would try the tftp downgrade commands from a controller.
I've successfully downgraded lots of 1260 series and 3500 series but this AP seems to have a new issue with the MODE button..
APa80c.0de7.1a3b#show ver
Not in Bound state.sion
*Mar  1 00:26:12.431: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Cisco IOS Software, C2600 Software (AP3G2-RCVK9W8-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 23:08 by prod_rel_team
ROM: Bootstrap program is C2600 boot loader
BOOTLDR: C2600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JA1, RELEASE SOFTWARE (fc1)
APa80c.0de7.1a3b uptime is 26 minutes
System image file is "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2602I-A-K9 (PowerPC) processor (revision A0) with 180214K/81920K bytes of memory.
Processor board ID FGL1750X0CF
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.5.1.73
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A8:0C:0D:E7:1A:3B
Part Number                          : 73-14588-02
PCA Assembly Number                  : 800-37899-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC17481M96
Top Assembly Part Number             : 800-38356-01
Top Assembly Serial Number           : FGL1750X0CF
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP2602I-A-K9
Configuration register is 0xF
APa80c.0de7.1a3b#
Everyone's tags (3)
2 ACCEPTED SOLUTIONS
Re: 2600 IOS conversion issues
You can also do it manually
In config mode
Debug capwap console cli
Debug capwap cli no reload
From here you can assign an address to the G0 Interface then
Archive download-software /f /o tftp://
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
VIP Purple
Hi Greg,
You can configure your TFTP/PC as gateway address for the LAP as shown below & then it should work.
LAP#debug capwap console cli
LAP#capwap ap ip address 10.10.10.102 255.255.255.0
LAP#capwap ap ip default-gateway 10.10.10.1 (your PC/TFTP IP address)
Refer this for detail
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Mode button option also should work. As long as your PC directly connected to the AP & AP ip address(10.0.0.1) configured as gateway for the PC things should work (even without that as well it should work as it use broadcast method). Link below give step by step process for that, give it another try & see
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Rasika
**** Pls rate all useful responses ***
In config mode
Steve
VIP Purple
Hi Greg,
Rasika
Thanks Guys,
I think I was missing the "debug capwap cli no reload" command.  After that I didnt have any of the DHCP reset messages and was able to tftp the code to the AP via "archive download-sw /force-reload /overwrite tftp://" without the interface resetting and tearing down the session.
Thanks for your response Rasika - unfortunately it seemed there was something buggy going on with the way the L2+3 wired interface when booted with the mode button held down.  No ARP entries for the IP it set to itself, no response to ping - didnt change anything physical or config wise on PC and reloaded the AP in CAPWAP mode, L3 worked enough to let me TFTP new code over.
Cheers,
Greg
354
