2601 controller issue
I have 3 cisco 2106 controllers. 2 are operating efficiently with no issues. I added a 3rd controller configured identical to the other controller other (ip address,etc). I can connect with a client to my guest network (10.100.8.0). When I try to connect to my internal Network (WLC), I can't. I noticed on the client that I see two identical ssids. Almost appears the controller is not syncing  with other controllers.
Here is the configuration on the switch:
interface FastEthernet4/0/17
description Wire_Control
switchport trunk allowed vlan 1,5
switchport mode trunk
storm-control broadcast level 10.00
macro description cisco-desktop | cisco-desktop
spanning-tree portfast
spanning-tree bpduguard enable
interface FastEthernet4/0/18
description Wireless Controller ip 10.100.0.49
switchport access vlan 5     (Do I need to remove this)
switchport nonegotiate
macro description cisco-desktop | cisco-desktop | cisco-desktop
The only difference I see, is the other two controllers have the same software version: 7.0.235.0
The new controller has software version : 7.0.235.3
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: 2601 controller issue
These controller's do not sync. They need to be configured separately which also means hostnames and IP address. A change in the ssid configuration means you have to manually change it on all there wlc's.
-Scott
-Scott
Maybe I used the wrong terminology (sync). "Static mobility groups members" I added the other two controllers.
All three WLC's should be on the same mobility group, unless they are not part of the same roaming area or if its a guest anchor wlc.  The trunk port doesn't need the switchport access command and really can be stripped down more:
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
129
