01-23-2014 05:54 AM - edited 07-05-2021 12:02 AM
1. Set a Static IP
2. Apply & Save Configuration
3. After Reboot the IP is correct.
Then do Reset to Defaults Except IP in the WEB Gui.
After Reboot the AP loos the static IP and get a DHCP Address.
Reset to Defaults Except IP = Reset to Defaults !
Whats Wrong ?
01-23-2014 05:57 AM
Try it again and console into the ap and reboot it. I would like to see the output.
01-23-2014 06:13 AM
OK, here is:
Writing out the event log to flash:/event.log ...
*Jan 22 17:44:56.675: %SYS-7-NV_BLOCK_INIT: Initialized the geometry of nvram
*Jan 22 17:44:57.547: %SYS-5-RELOAD: Reload requested by on console. Reload Reason: Reload Command.
Write of event.log done
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP: Numonyx Mirrorbit (0089)
Xmodem file system is available.
flashfs[0]: 212 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 15058432
flashfs[0]: Bytes available: 16939520
flashfs[0]: flashfs fsck took 23 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 10:f3:11:c2:2e:3a
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w7-mx.152-4.JB3a/ap3g2-k9w7-mx.152-4.JB3a"...##########################
File "flash:/ap3g2-k9w7-mx.152-4.JB3a/ap3g2-k9w7-mx.152-4.JB3a" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Tide MB - 32MB of flash
flashfs[0]: flashfs fsck took 14 seconds.
Boot CMD: 'boot flash:/ap3g2-k9w7-mx.152-4.JB3a/ap3g2-k9w7-xx.152-4.JB3a;flash:/ap3g2-k9w7-mx.152-4.JB3a/ap3g2-k9w7-mx.152-4.JB3a'
Loading "flash:/ap3g2-k9w7-mx.152-4.JB3a/ap3g2-k9w7-xx.152-4.JB3a"...#######################################
File "flash:/ap3g2-k9w7-mx.152-4.JB3a/ap3g2-k9w7-xx.152-4.JB3a" uncompressed and installed, entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3600 Software (AP3G2-K9W7-M), Version 15.2(4)JB3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 23-Dec-13 08:11 by prod_rel_team
Initializing flashfs...
flashfs[3]: 212 files, 7 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 31739904
flashfs[3]: Bytes used: 15058432
flashfs[3]: Bytes available: 16681472
flashfs[3]: flashfs fsck took 12 seconds.
flashfs[3]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCCCC
Uncompressing radio files...
...done Initializing flashfs.
Radio0 present 8764 8000 0 A8000000 A8010000 0
Rate table has 650 entries (20 legacy/224 11n/406 11ac)
POWER TABLE FILENAME = ram:/B2.bin
Radio1 present 8764 8000 0 88000000 88010000 4
POWER TABLE FILENAME = ram:/B5.bin
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco AIR-SAP2602E-E-K9 (PowerPC) processor (revision A0) with 204790K/57344K bytes of memory.
Processor board ID FGL1711Z6K6
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 10:F3:11:C2:2E:3A
Part Number : 73-14511-02
PCA Assembly Number : 800-37898-01
PCA Revision Number : A0
PCB Serial Number : FOC17093TXF
Top Assembly Part Number : 800-38357-01
Top Assembly Serial Number : FGL1711Z6K6
Top Revision Number : A0
Product/Model Number : AIR-SAP2602E-E-K9
Press RETURN to get started!
*Mar 1 00:00:16.035: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table No such file or directory
*Mar 1 00:00:16.151: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (11)APAVC: WlanPAKs 18174 RadioPaks 17566
*Mar 1 00:00:23.131: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:29.443: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar 1 00:00:29.503: initializing dot11 onplus
*Mar 1 00:00:29.667: not a autoconfig enabled device!!!
*Mar 1 00:00:31.671: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:32.671: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 1 00:01:18.015: Starting Ethernet promiscuous mode
*Jan 22 17:44:57.000: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 22 17:44:57.000: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 22 17:44:57.007: %CDP_PD-4-POWER_OK: Full power - HIGH_POWER inline power source
*Jan 22 17:44:57.015: %SYS-5-RESTART: System restarted --
*Jan 22 17:44:57.015: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Jan 22 17:44:57.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Jan 22 17:44:57.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jan 22 17:44:57.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to downERROR: Failed to configure ethernet promiscuous mode. Interface Descriptor mismatch
*Jan 22 17:45:01.667: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (0-0)
*Jan 22 17:45:01.667: DPAA Initialization Complete
*Jan 22 17:45:01.667: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Jan 22 17:45:02.667: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Jan 22 17:45:06.863: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.16.33.216, mask 255.255.254.0, hostname ap
01-23-2014 06:18 AM
Can you add a static and then just reboot the AP. Just want to compare the output. Don't reset to default.
Also can you post the show ip int brief before and after.
01-23-2014 08:41 AM
Here is the show ip dump:
show ip interface
BVI1 is up, line protocol is up
Internet address is 10.16.33.100/23
Broadcast address is 255.255.255.255
Address determined by configuration file
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Multicast reserved groups joined:
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is disabled
IP fast switching on the same interface is disabled
IP CEF switching is disabled
IP Null turbo vector
IP multicast fast switching is disabled
--More-- IP multicast distributed fast switching is disabled
IP route-cache flags are Fast
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is disabled
Network address translation is disabled
BGP Policy Mapping is disabled
Input features: MCI Check
Dot11Radio0 is administratively down, line protocol is down
Internet protocol processing disabled
Dot11Radio1 is administratively down, line protocol is down
GigabitEthernet0 is up, line protocol is up
ap#
Cant find the add static command.
01-23-2014 10:09 AM
I think Scott mean configure a static IP on your BVI1 interface & save the config & reload. Something like this.
ap#conf t
ap(config)#int bvi1
ap(config-if)#ip add 10.16.33.33 255.255.254.0
ap(config-if)#end
write mem
reload
See wether IP address get dissapear after reload
Rasika
*** Pls rate all useful responses ****
01-24-2014 12:07 AM
Thank you Rasika,
Here is the BVI1 after Reload.
BVI1 is up, line protocol is up 1 00:00:29.675: not a autoconf
Hardware is BVI, address is 10f3.11c2.2e3a (bia 10f3.11c2.2e3a)
*Mar 1 00:00:31.675: %LINK-6-UPDOWN: Interface Gigabi
MTU 1500 bytes, BW 54000 Kbit/sec, DLY 50
If I set the BVI1 Interface over cli or gui the ip parameter are saved correkt and the ap
after boot or reload have the correkt ip.
The problem is the "Reset to Defaults (Except IP)" Button on Gui.
If i click the button the ap set all parameters to defaults and the BVI1 to DHCP.
But "Except IP" shold be not change the ip !
01-24-2014 12:33 AM
Ok, If you have tested it & everytime behaviour is same (you loose the IP config once you do this via GUI) it may be GUI related bug.
You can try this with different IOS image (upgading or downgrading) & see whether behavioiur is same ? if not it may be specific to the code you are running.
Rasika
**** Pls rate all useful responses ****
01-24-2014 01:15 AM
The Version is: ap3g2-k9w7-xx.152-4.JB3a
It´s definitly a gui related bug.
Insted a "reset to defaults except ip" i load a default config with correct ip settings.
Hope this bug will be solved in the future.
01-24-2014 01:31 AM
These are the only Open Caveats in 15.2(4) JB3a:
Open Caveats
CSCud51131 CLI required to configure IPv6 SNTP server addresses.
CSCue53185 The allowed frequencies are repeated in show controllers dot111 command for Japan regdomain.
CSCuf85579 Multicast downstream fails on a wlan client with security wpa2-tkip on enabling broadcast key rotation.
CSCui79550 GUI IP Protocol 119 column missing on the QoS policies page.
CSCuj62328 Apple client is not associating with 11r SSID.
CSCul91975 WGB may disconnect permanently after max retry of 802.11 probe.
If you can reproduce this BUG then U can raise a TAC case, it may help to other.
01-24-2014 05:26 AM
Downgrade the version to v12.4... v15 is no good... Too many complaints with the newer version. The latest v12.4 is what you should use.
01-24-2014 05:31 AM
Well they use to have a v12.4 for the ap3g2 AP's you can use... They removed it. So now you just have to try one of the other v15 code versions. The newer code is awful and I have no idea why they went that route.
01-24-2014 05:39 AM
Ah now I remember... The radios for the 1262's and the 3600's were the same, so you were able to load the 1262 code into the 3600. I'm guessing since the 3600 is the higher version of the 2nd gen you might be able to use it on the 2600 also. If I have time today I'll test that.
Is defaulting the AP except for an IP something you really want to work? I mean you can write erase on the CLI and put the static back on and personally, autonomous AP's should be configured from the CLI. Just wondering if you want to go through the hassle if upgrading or downgrading because of that one issue. I would be worried a both other issues that might affect production.
