2602i humidity question
Does anyone have experience placing access points in high humidity environments?
We are considering placing a 2602i access point in an office that is within an indoor pool area. The spec sheet for the 2602 says the operating humidity
is 10-90% noncondensing, but I'm not sure what the noncondensing part means.  Is the 2602i sealed well enough to prevent condensation from building up inside it from from humidity?  Will this model ap withstand a humid pool environment, and if not, which model would?
Hall of Fame Super Silver
Re: 2602i humidity question
That means that it's not accumulating moisture. Is the AP sealed enough... Not for heavy humidity. I have seen AP's in pool areas last long and fail within a year, so it varies. You might want to put the AP in a sealed enclosure possibly or even place AP's in a different room and run antennas to the pool area.
-Scott
Scott,
Thank you, what type of enclosure should we be looking at?  Also, it's not the pool area itself we are providing coverage to, but an office inside the enclosed pool area for an office worker.  I'm guessing the level of humidity would be the same though as if it were actually positioned near the pool.
VIP Purple
Thanks, I will look at those.
No problem. It does cost a lot, but you might just be able to get one without a heater and one with a fan and antenna mounted on the bottom side which should work for you if you do want to mount it in the pool area.
-Scott
Typically offices around the pool are we have deployed access points without enclosures. These rooms usually have AC or fans which keeps the humidity down. You should reach out to Tessco for more info as they have specific enclosures for the model of AP's you have.
http://www.tessco.com
-Scott
Here is a list of enclosures that might work... They have fans and ap and fan is powered up with a single PoE cable run.
http://www.tessco.com/products/displayProducts.do?groupId=3093681&subgroupId=95157
-Scott
Ok, thanks, I will look at those
178
