Community Member
2702i convert to Autonomous mode
Hi netpro,
I am having some difficulties trying to get a new 2702i to convert into standalone / autonomous mode.
I've done what most articles say you should do. First SSH into AP, have it pull the ios file that needs to be renamed to .default. (full name :ap3g2-k9w8-tar.default)
What happens is that the AP begins pulling from the TFTP and then restarts. However when it restarts i can not ssh back into the AP.
I see it pulls the same IP or a different IP, but i can not ssh or get webaccess into the AP. Console doesn't work at all either. I am using a usb to console cable that i know works. Here is the log upon downloading the new file from the tftp
APf8c2.88bc.75fc#archive download-sw /force-reload /overwrite tftp://192.168.1.147/ap3g2-k9w8-tar.default
examining image...
Loading ap3g2-k9w8-tar.default from 192.168.1.147 (via BVI1): !
extracting info (286 bytes)
Image info:
    Version Suffix: k9w8-.152-4.JB5
    Image Name: ap3g2-k9w8-mx.152-4.JB5
    Version Directory: ap3g2-k9w8-mx.152-4.JB5
    Ios Image Size: 215552
    Total Image Size: 13701632
    Image Feature: WIRELESS LAN|LWAPP
    Image Family: AP3G2
    Wireless Switch Management Version: 7.6.100.0
Extracting files...
ap3g2-k9w8-mx.152-4.JB5/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/ap3g2-k9w8-mx.152-4.JB5 (208427 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/ap3g2-k9w8-tx.152-4.JB5 (73 bytes)
ap3g2-k9w8-mx.152-4.JB5/html/ (directory) 0 (bytes)
ap3g2-k9w8-mx.152-4.JB5/html/level/ (directory) 0 (bytes)
ap3g2-k9w8-mx.152-4.JB5/html/level/1/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/1/appsui.js (563 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/1/back.shtml (512 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/1/forms.js (20125 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/1/sitewide.js (17089 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/1/config.js (26330 bytes)!
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/1/officeExtendap.css (41801 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/1/ap_home.shtml.gz (1297 bytes)
ap3g2-k9w8-mx.152-4.JB5/html/level/1/images/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/1/images/background_web41.jpg (732 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/1/images/cisco-logo-2007.gif (1648 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/1/images/info.gif (399 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/1/images/login_homeap.gif (19671 bytes)
ap3g2-k9w8-mx.152-4.JB5/html/level/15/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/15/officeExtendapBanner.htm (7114 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/15/officeExtendapConfig.shtml.gz (2864 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/15/officeExtendapEvent.shtml.gz (988 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/15/officeExtendapHelp.htm (5013 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/15/officeExtendapMain.shtml.gz (3350 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/html/level/15/officeExtendapSummary.htm (718 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/ap3g2-k9w8-xx.152-4.JB5 (12061500 bytes).!O!!!!!!!!!!!!!!!!.OO!!!!!!!!!!!!.!O!!!  !!!!!!.!O!!!!!!!!.O!
extracting ap3g2-k9w8-mx.152-4.JB5/8004.img (554707 bytes)!!
extracting ap3g2-k9w8-mx.152-4.JB5/E2.bin (18656 bytes)!
extracting ap3g2-k9w8-mx.152-4.JB5/E5.bin (1816 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/X2.bin (15158 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/X5.bin (1519 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/V2.bin (12826 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/V5.bin (525 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/R2.bin (9328 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/R5.bin (3406 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/Q2.bin (5830 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/Q5.bin (2790 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/C2.bin (19822 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/C5.bin (6936 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/F2.bin (13992 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/F5.bin (3662 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/U2.bin (6996 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/U5.bin (3048 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/B2.bin (9328 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/B5.bin (1980 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/Y2.bin (5830 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/Y5.bin (1544 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/8006.img (544404 bytes)!!
extracting ap3g2-k9w8-mx.152-4.JB5/info (286 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/file_hashes (6353 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/final_hash (141 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/img_sign_rel.cert (1375 bytes)
extracting ap3g2-k9w8-mx.152-4.JB5/img_sign_rel_sha2.cert (1371 bytes)
extracting info.ver (286 bytes)
[OK - 13721600 bytes]
Deleting target version: flash:/ap3g2-k9w8-mx.152-4.JB5...done.
New software image installed in flash:/ap3g2-k9w8-mx.152-4.JB5
Configuring system to use new image...done.
Requested system reload in progress...
Any help would be appreciated !
1 ACCEPTED SOLUTION
VIP Purple
Hi,Be aware that the
Be aware that the autonomous IOS for the 2700 has limited functionality. Because the 2700 is new, the autonomous IOS is for wireless site-survey only.  It's not meant to service clients as of yet.
You are extracting ap3g2-k9w8-tar.default image from tftp and this image type is not right to convert to Autonomous.
(k9w7 is Autonomous Image), you need to download this image.
http://rscciew.wordpress.com/2014/01/04/understand-access-point-ios-images/
http://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
Dont forget to rate helpful posts
VIP Purple
Community Member
Thank you very much!!! Once i
Thank you very much!!! Once i changed the image to K9w7, it worked!
Community Member
seealso:https://supportforums
see also:
https://supportforums.cisco.com/discussion/12241326/aironet-2702-autonomous-mode
Community Member
Where did you find the
Where did you find the autonomous ios download? I've searched the Cisco site and can't find it in the download section.
Community Member
you need to download from
you need to download from another AP model, for example go to the 2600 series and you will see the option to download the Autonomous AP IOS Software. Here is a direct link :
http://software.cisco.com/download/release.html?mdfid=284362257&flowid=34153&softwareid=284180979&release=15.2.4-JB5&relind=AVAILABLE&rellifecycle=ED&reltype=latest
5249
