2n+1 redundancy with 2x5500's + 1x4402
srue
Level 7
Level 7
Is it possible to have AP's on a 5500 controller failover to a 4402 if they're running the same software version?  Will the AP's try to update their code upon failover?
(this isn't my design, but I might be forced to implement it if it's possible).
TIA
Stephen Rodriguez
Yes, you can have AP's failover from the 5500 to a 440x, and if the controllers are running different codes, then the AP will pull the correct code for the WLC that it is attached to.
There is no difference between how the controllers support the AP, just the number they can support, platform features aside, i.e OEAP, guest anchoring etc.
Now, if you are working to have redundancy, you should have the controllers on the same code, and if you are using AP groups, the group settings need to match across the controllers as well.
HTH,
Steve
*Please remember to rate helpful posts*
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Leo Laohoo
Don't see any issues with this ... *drum rolls please* ... as long as you are not running something "exclusive" only to the 5508 such as OfficeExtend.
