04-25-2003 03:14 PM - edited 07-04-2021 08:39 AM
Does anyone know of the maximum number of clients that can be supported an a 350 bridge running in AP mode. I need to provide network connectivity to a housing estate (1.5-2mile radius) at a minimum of 1 Mbs. I was thinking of using the 350 since it seems to support the high gain antenna while the AP 350 does not.
Assuming the BR 350 supports 64+ clients, can anyone see any problems with such an implementation? Help is appreciated.
Many thanks
Omar
Solved! Go to Solution.
04-28-2003 04:44 AM
In access point mode it should be able to handle over 2,000 clients. Of course they would all be using a portion of the bandwidth since it is shared. There should be no problems with your setup. Just keep in mind the more users there are the less bandwidth each one will have.
04-28-2003 04:44 AM
04-28-2003 05:21 AM
Many thanks. I will try the setup with the high gain antenna.
Omar
