Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
350 series Wireless Bridge / VLANs
I want to have a connectivity as follows:
clients--AP-BR------2Km------BR-AP-clients
Few Questions
1. Is this a correct design ?
2. What will be the relationship between the AP & BR?
3. Do I really need both the AccessPoint and the Wireless Bridge at both ends?
4. I was wondering if the Bridge can serve the clients then I can get away with the AP?
5.There is a need to put the two sets of clients in different VLANs (broadcast domains) without going wired (they will be in different IP subnets). I know that I can go wired and put a Router or a L3_Switch some where in between to do the Inter-VLAN routing,,, but since the requirement is for a complete wireless network, I would need the routing functionality on the wireless device; any suggestions?
Your help will be highly appreciated.
Ahmer Ghazi
Re: 350 series Wireless Bridge / VLANs
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources at the online http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Your drawing is the most reliable option, but also the most expensive. Using the 'Remote with clients' option may allow you to skip one AP, but will cut performance by as much as 50%. There is no 'Master with Clients' (unless it's been added since the last time I looked) setting, so this only cuts out one AP, not both.
This type of config is one of the reasons Cisco created the 1200 series - it would take two cards, as does the Agere dual-slot AP, but that has lower transmit power, weaker receive sensitivity and a few other differences.
At 2Km, you probably don't want to try to hit the clients directly unless you can mount a small antenna on the back of the monitor.
Can you not plug the AP and the Bridge at one location into a Layer3 capable switch to get your separate VLANs?
Matthew Wheeler
Blue Modal
237
