Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
3502I Access point not registering
       We have a new setup coming where we have no DHCP available so we configured switch as DHCP and with Option 43 for WLC ip.
AP gets an ip but its loosing its ip and going back to default ip of 10.10.1.10.
Any clue why.
I have configured switch port as trunk
dhcp shows bindings but AP not retaining this ip for long enough is there an issue with completing the registration process.
ANy ideas thoughts welcome.
Everyone's tags (2)
VIP Purple
Re: 3502I Access point not registering
Hi Mathew,
Example to configure DHCP on swicth for APs
Core Switch Configuration"
ip dhcp excluded-address 10.99.80.1 10.99.80.100
ip dhcp excluded-address 10.99.80.110 10.99.80.254
ip dhcp pool WirelessLAN
   network 10.99.80.0 255.255.255.0
   default-router 10.99.80.254
   option 43 ip 10.99.80.1
   option 60 ascii "VCI string"
  lease 3
interface Vlan80
ip address 10.99.80.254 255.255.255.0
For AP connection:
Interface fa0/xx
Switchport mode access
Switchport access vlan 80
Hope it helps.
Dont forget to rate helpful posts.
i have configured this same way. Only difference is switch port is configured as trunk as this is a Hreap AP.
VIP Purple
did u configured option 60 for 3503 AP.
put logs from controller to find out the exact cause.
Reagrds
nope i havent configured it.are you asking me to put vendor code?
VIP Purple
HI,
DHCP Option 43 is limited to one access point type per DHCP pool. You must configure a separate DHCP pool for each access point type.
The 3502P access point uses the type-length-value (TLV) format for DHCP Option 43. DHCP servers must be programmed to return the option based on the access point's DHCP Vendor Class Identifier (VCI) string (DHCP Option 60). The VCI string for the 3502P access point is:
Cisco AP c3502
The format of the TLV block is listed below:
•Type: 0xf1 (decimal 241)
•Length: Number of controller IP addresses * 4
•Value: List of WLC management interfaces
still not work then please Console into the AP and post the output.
option 60 ascii Cisco AP c3502
is this correct?
VIP Purple
This is right .
Can u please post the logs from AP.
Silver
Hall of Fame Super Gold
Post the following output:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh inventory; and
5.  AP:  sh ip interface brief
393
